Viewing 15 posts - 4,726 through 4,740 (of 6,219 total)
  • in reply to: General Configuration Sequence #3840
    On step 3 I tried to open Communicator. Instead of seeing Communicator with the arrow button, I got the Scheme Editor.
    Could you provide screenshots describe the things you did?
    in reply to: Web Page don't open in other computers. #3835
    Seems, you do the right things.
    Can you open Rapid SCADA from other computers within your network?
    How do you connect from the outsite? Do you use dynamic DNS?
    in reply to: International Character Bug #3825
    Can you play with it using Chrome feature?
    1. Try switching off font style.
    2. Try type different symbols manually.
    3. Try enter this symbol somewhere else in the page.
    What are the results?
    in reply to: Change Text of dynamic text element by fomular #3824
    All content of scada_guide_3_en.pdf was moved to http://doc.rapidscada.net/content/en/
    Just ask here about formulas.
    in reply to: International Character Bug #3806
    If you open the command dialog, press F12 in Chrome and check the Elements tab. How this symbol is displayed? Probably, the bug in HTML or styles.
    in reply to: International Character Bug #3798
    The web app uses Open Sans font. Please check if it contains the required character.
    in reply to: International Character Bug #3797
    Please check it in the configuration database in DAT format using UI of SCADA-Server. Could you provide screenshots?
    in reply to: Trying to communicate with Chinese 8IN8OUT device #3796
    Even if you poll incorrect registers, the device must answer meaningful error package.
    in reply to: Trying to communicate with Chinese 8IN8OUT device #3795
    Seems, you do everything right.
    Is there any controller manual with request-response examples?
    in reply to: Write config back to database #3786
    The plan for the future is that a user creates a project on any computer and then deploy (publish) the project on a working Rapid SCADA instance.
    Probably, you mean some kind of back import from runtime configuration to a project. This may be an extension for the Administrator app.
    We are going to create new generation of Administrator where configuration process will be more solid. And may be this problem will disappear.
    in reply to: Data input #3775
    When we complete this module, you can specify SQL request to retrieve data from a database which has any structure. We are going to support Oracle, MS SQL, PostgreSQL and MySQL. You don’t need files working with DB.
    in reply to: How to send value #3774
    You have to create an output channel and specify it in a scheme or a table view.
    What is a particular issue? You can’t display a form to input a value or you can’t store it into a variable?
    in reply to: Data input #3771
    In this year it’s planned to develop a module that will receive data from a 3rd party database as input. As for me, Excel is not a good data source because it is not stable.
    Agent is not included in the distributive package. You should install it separately. At least in this year, it will be a separate application.
    in reply to: MQTT driver publish comma decimal point #3764
    Hi Peter,
    I suggest to create an issue on GitHub https://github.com/bersim/OpenKPs/tree/master/KpMQTT
    If you do this, the author of this driver receives a notification
    If you need, the dlls are here
