How to send value
Forum Home › Forums › Understanding the Software › How to send value
Viewing 10 posts - 1 through 10 (of 10 total)
  • #3773
    Marko
    I want to input some value in local variable of SCADA or PC. I already tried
    with Set Val formula and that is working but only if you want to input some static value.
    How to input some value directly to local variable using PC keyboard?
    I want to type some value in local variable.
    #3774
    You have to create an output channel and specify it in a scheme or a table view.
    What is a particular issue? You can’t display a form to input a value or you can’t store it into a variable?
    #3776
    Marko
    I can’t store some value in variable.
    #3777
    Marko
    Just to give you example what i want to do. I want to press some box that will open popup like you want to send command and there you have window where you input some value 25 or 53 or 86 and when you press ok and popup closed i want to see that value in some input channel.
    #3778
    CmdVal, Cmd double The command value transmitted to Server before calculation
    http://doc.rapidscada.net/content/en/software-configuration/using-formulas.html
    #3779
    Marko
    Can you be more specific? How should i setup input and output channel in that case?
    #3780
    screen1
    screen2
    screen3
    screen4
    In the input channel, specify the output channel number, in the output channel, configure the Standard command. You can also add a formula if necessary, without adding a formula additional actions are not required. Sorry, but my test system is in Russian.
    On the website in addition to the documentation seems to be the video lessons, well, you just have to try different options.
    • This reply was modified 8 years, 5 months ago by manjey73.
    #3783
    Marko
    Thank you very much. It’s working now.
    #8230
    dinop
    I don’t know if it’s the right place to post a question but here it is.
    I want to know if is possible to send command from Rapid Scada to PLC.
    I created a screen with Scheme editor and I want to create a button that will be an input for PLC (for example: a button which starts a sequence)
    Is that possible and how?
    I created a BOOL inside TIA Portal. Now what? How to declare it in Rapid scada to perform a task such as, start sequence.
    Communication used is OPA UA.
    #8233
    Please make screenshots of the OPC UA configuration in Communicator and screenshot of output channels that are used for sending commands.
    As I remember, sending commands is shown in Modbus video. For OPC UA it is close.
