Write config back to database
Forum Home › Forums › New Ideas › Write config back to database
  • #3784
    Podolski
    If I modify the connection parameters such as call number in the scadacommctrl rather than in Admin. The parameters can be saved in the scadacommctrl, however it will not pass back to Admin database. It may cause confusion among users. How about a write back to admin feature in scadacommctrl? Do you have any ideas?
    #3786
    The plan for the future is that a user creates a project on any computer and then deploy (publish) the project on a working Rapid SCADA instance.
    Probably, you mean some kind of back import from runtime configuration to a project. This may be an extension for the Administrator app.
    We are going to create new generation of Administrator where configuration process will be more solid. And may be this problem will disappear.
