Viewing 15 posts - 4,606 through 4,620 (of 6,219 total)
  • Mikhail
    Likely you need to add access rights to the scada/ScadaWeb directory. Try 777 recursive rights.
    in reply to: Development of Rapid SCADA project #4163
    Of course, software development using Rapid SCADA as a platform is a part of our business. Please, send us by email the description of your task and the requirements, and we discuss a solution and price.
    in reply to: Try to integrate with IED using DNP3 Protocol #4160
    To connect a DNP3 device you should use an OPC server that supports this protocol.
    We would develop a native DNP3 driver for Rapid SCADA if some company sponsored such development.
    in reply to: How to add new Unit indicator to administrator #4157
    To add a new row, scroll down to the end of the table.
    in reply to: How to add new Unit indicator to administrator #4156
    In Administrator open the Units table and add a new unit. Then refresh the Input Channels table to be able to choose the new unit.
    in reply to: Setting Alarm threshold #4152
    1. In Administrator open the Units table and add new row:
    ID = 101, Name = MyAlarm, Sign = Off;On;On
    You at least need 3 values to color them.
    2. Open the Formulas table and add a new formula:
    int MyStat()
    return Cnl > 0 ? 114 : 13;
    3. Use the formula for an input channel: Cnl; MyStat()
    and set MyAlarm unit for the channel.
    Hope this help.
    • This reply was modified 7 years, 7 months ago by Mikhail.
    in reply to: Get rid of Execute command confirmation windows #4150
    Yes )
    Choose an option “Send command now” when setup a properies of a component.
    Thank you 🙂
    in reply to: Setting Alarm threshold #4147
    If the existing statuses are not enough for you, you can add your own statuses.
    in reply to: Setting Alarm threshold #4146
    How to change the channel Lower alarm limit; lower limit; upper limit; upper alarm limit ,from the web interface.
    You can’t. If you need to change limits, create additional input channel that represent limits. And then calculate a status of a controlled channel by your own formula.
    If using two channels for comparison,How to do change the event color?
    You need to set input channel status. A formula is like that: MyVal(); MyStat()
    where MyVal and MyStat are the functions that calculate value and status.
    Or just: Cnl; MyStat()
    If you don’t need to change value.
    Yes, you can find it in MasterMain.Master
    But there are also might be a product name in different files.
    According to the licence, you have to keep the information about the original product visible to a user. For example, keep the About page unchanged.
    in reply to: Rapid Scada Update and license key #4140
    OK,
    If it occurs again, please send me the log folders.
    in reply to: Rapid Scada Update and license key #4138
    Can you post here a link to download the full log folder of SCADA-Server when the issue occurs?
    The thing is that stopping procedure is simple, and it’s strange that the service can’t stop.
    in reply to: Intergration data input into cloud system #4137
    Likely, an integration software module should be developed to complete this task.
    in reply to: Formulas Math Functions #4136
    The example shows daily difference. Elastic Report also supports hourly difference. In case of 8 hours difference, we can discuss implementing this feature.
