Viewing 15 posts - 4,366 through 4,380 (of 6,219 total)
  • in reply to: 5.6.0 Web is not normal #4814
    I can connect to your PC remotely and fix the issue. This is a commerical service. To get it, please contact us by email.
    in reply to: Formulas Math Functions #4813
    How can I do this?
    For example, Cnl * 10
    is it possible to implement a digital momentary start/stop?
    Please clarify the question.
    in reply to: How to install rapidscada in Windows xp OS? #4812
    Rapid SCADA requires .NET Framework 4.6 or higher. You need at least Windows 7. See this
    in reply to: 5.6.0 Web is not normal #4808
    There was no changes in the project format. To get more error details, press F12 in a browser and watch the Console tab.
    in reply to: How to install rapidscada in Windows xp OS? #4807
    I’m afraid that Windows XP is too old. You can’t install .NET Framework 4.6 on XP that is required for Rapid SCADA.
    in reply to: 5.6.0 Web is not normal #4804
    After the update,paste the old project.
    Did the problem appears only when you apply the old project? Does it work after clear installation?
    in reply to: Ubuntu Installation Forbidden from Apache2 #4803
    Thanks for the solution ))
    Also the web site referenced in the install_with_apache.txt file does not resolve
    That’s true. That’s why there is a ready file scada.conf in the distributive package.
    in reply to: Function 05, Force single coil #4797
    Check Commands enabled checkbox of a communication line. If it doesn’t help, copy communication line log here in a moment of sending command.
    in reply to: Change Led colour #4794
    Can I do it for 2 conditions?
    Yes.
    a ? b ? c : d : e
    I forget how the above works ))
    in reply to: DotNet Framework issue #4793
    In 2019 we may move to .NET 4.7, so you probably should think about upgrading the server OS.
    .NET 4.7 is required to use the same .NET Standard DLLs with cross-platform .NET Core build of Rapid SCADA.
    in reply to: 5.6.0 Web is not normal #4791
    Press Ctrl+F5 to refresh all the scripts.
    in reply to: SCADAComm stop attempt to reconnect when communication failed #4790
    If you send me an email to info@ , I will forward your message to bersim.
    in reply to: DotNet Framework issue #4789
    You can try copying Web.config from the previous version. Does it help?
    in reply to: How long the ScadaCommCtrl's log is saved ? #4783
    i fond that the log.bak file max. size is 1MB(1025Kb),not is 10MB
    example : line050.log.bak 1025KB
    My fault, sorry.
    is there plan to provide config for log?
    This issue is minor for the most users. We can do it faster for a donation.
    in reply to: Extra Scheme Components Plugin #4775
    The components were published on July 30, 2018. So you need at least Webstation 5.0.6.1.
    See the version history for the details.
