Viewing 15 posts - 3,931 through 3,945 (of 6,218 total)
  • in reply to: Auto Control for Telegram configuration #6006
    Can’t access photo. Please provide public access to it.
    Also you should check the version of C:\SCADA\ScadaServer\Mod\ModAutoControl.dll
    Don’t forget to upload project changes to a server.
    in reply to: Auto Control for Telegram configuration #6003
    1. Screenshot of the output channels table.
    2. Log of Auto Control Module.
    3. Communicator log. It shows when new a command is received.
    in reply to: Device Recommendation? #5997
    If you need to switch ON/OFF something, you can choose ADAM-6060, for example.
    in reply to: Device Recommendation? #5995
    Do you need to embed video stream in SCADA user interface, or cameras provide variables using some communication protocol, for example, SNMP?
    in reply to: DF1 PLC Protocol driver Allen Bradley #5992
    Good news!
    What Communicator version is needed?
    in reply to: New Rapid SCADA 5.7.0 Beta #5989
    I see. Did you find the filter feature?
    in reply to: How to modify many database fields content easily? #5987
    To find the best method, please provide an example what do you need to update.
    in reply to: New Rapid SCADA 5.7.0 Beta #5984
    Yes, I understand. This button is removed. Instead of this, you can use a filter of the Input channels table to filter the records by an object.
    Why grouping by devices is not enough for you? What is the specifics of your system?
    The GenEvent method is used to generate events. You should find references to the method for researching detailed logic. If you ask particular questions, I’ll try to clarify them.
    in reply to: OPC UA Driver #5980
    The driver user interface is implemented.
    in reply to: New Rapid SCADA 5.7.0 Beta #5976
    Use filter of a table.
    in reply to: Gensets controllers monitor using Rapidscada #5975
    Can i extract data from them? Or must use modbus port?.
    Please read the manual. Likely, you can use Modbus TCP.
    First, try to use built-in Ethernet port of the controller if it is presented. I’m not DSE guru, but talk from common point of view.
    in reply to: OPC UA Driver #5972
    Thank you for checking. I added BouncyCastle.Crypto.dll to the ZIP file.
    I also tested the driver on Linux. It works but requires an extra step in configuring. If needed, I will describe here.
    in reply to: Gensets controllers monitor using Rapidscada #5971
    I’ve got a Modbus template for some model of DSE controller. I can share it in case you will share the final template for DSE 7320.
    in reply to: Gensets controllers monitor using Rapidscada #5970
    DSE 7320 supports Modbus communication protocol, so it can be connected to Rapid SCADA.
    You should do the following:
    1. Read this article and watch this video.
    2. Create your own simple project to read data from Modbus simulator.
    3. Find the Modbus register map for DSE 7320 in the manufacturers documentation.
    4. Create your Modbus template DSE 7320 for that specifies the registers to read.
