Change event contains columns, increase whether to eliminate and eliminate time Forum Home › Forums › Development and Integration › Change event contains columns, increase whether to eliminate and eliminate time This topic has 1 reply, 2 voices, and was last updated 7 years ago by Mikhail. Viewing 2 posts - 1 through 2 (of 2 total) Author Posts September 29, 2019 at 8:25 am #5981 fjyyjParticipant Hi Mikhail, Can you tell me the process of event generation and the objects and classes involved in it? September 30, 2019 at 1:16 pm #5982 MikhailModerator Hi, The GenEvent method is used to generate events. You should find references to the method for researching detailed logic. If you ask particular questions, I’ll try to clarify them. Author Posts Viewing 2 posts - 1 through 2 (of 2 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
