Forum Home › Forums › Development and Integration › Auto Control for Telegram configuration
- This topic has 7 replies, 2 voices, and was last updated 7 years ago by
October 24, 2019 at 10:13 am #6002
ofizcloud
I’m trying to create a auto control to send Telegram message on trigger. I have configured the auto control as following
https://i.imgur.com/Oidhhdl.pngAccording to the log, seems like the auto control is working. But there is no any telegram message sent. Is there anything wrong with the config?
Regards,William
October 24, 2019 at 2:58 pm #6003
1. Screenshot of the output channels table.
2. Log of Auto Control Module.
3. Communicator log. It shows when new a command is received.October 25, 2019 at 9:28 am #6005ofizcloud
ParticipantOutput channel table :
Auto Control Module log
Communicator log
October 25, 2019 at 1:29 pm #6006
MikhailModeratorCan’t access photo. Please provide public access to it.
Also you should check the version of C:\SCADA\ScadaServer\Mod\ModAutoControl.dll
Don’t forget to upload project changes to a server.October 28, 2019 at 4:19 am #6012ofizcloud
ParticipantThis is the updated link for the photo :
https://photos.app.goo.gl/WtEtDZ5KHDdAYpq96
ModAutoControl.dll installed is version 5.2.4.0
Changes has been uploaded to server.
October 28, 2019 at 11:27 am #6016
MikhailModeratorThe module version is fresh.
The line in the log “Command is enqueued to be sent at 16:10:49. Device 0, Command 1” says that output channel number was not applied.
Try checking C:\SCADA\ScadaServer\Config\ModAutoControl.xml
Other way, in the trigger settings instead of output channel, specify the device number.
Also I can fix this remotely for a fee if needed.
October 29, 2019 at 5:53 am #6018ofizcloud
ParticipantThanks Mikhail,
I fixed it. I need to set the user to 1 on the command to get make it work. Previously I left it as 0.
October 29, 2019 at 2:41 pm #6021
MikhailModeratorUser is optional. Probably, changing user somehow updated the output channel number.
