Viewing 15 posts - 3,841 through 3,855 (of 6,218 total)
  • in reply to: Elastic report — non clickable link #6257
    Make sure that Elastic Report plugin is activated in Webstation at http://localhost/Scada/plugins/Config/Plugins.aspx
    If it doesn’t help, provide more different screenshots.
    in reply to: Building the app error #6256
    i taked to code source from github, but i will try with your link !
    My link is also GitHub.
    i try to use the ServerAdmin5, because the classic ServerAdmin
    That’s correct.
    i try to build ScadaAdmin5 i need the ScadaWebCommon5 Assembly but i only have the classic ScadaWebCommon
    Current name is ScadaWebCommon. The issue is strange. Could you make a screenshot of Visual Studio solution explorer with expanded References node?
    Anyway, I suggest to add PlgElasticReport_Reg.xml into your project.
    If you uncheck “Ignore Registration keys”, it means that registration keys are not ignored and uploaded.
    in reply to: Building the app error #6244
    You should get the source code from the master branch v5.7.1
    In this case, I hope, the projects will be consistent. And you get the same binaries that are included in the installation package.
    it say that WebUtils don’t have a method named QueryParamToIntArray
    This method was deleted recently.
    in reply to: Remove unused Views #6243
    First, you should delete from the Rights table. Then from the Interface table.
    When you delete from disk, there is no reference check.
    in reply to: MQTT in-depth Installation Help #6242
    The message in the screenshot is not a error. You should check communication line log.
    Where did you download KpMqtt.dll from?
    in reply to: Runtime Error on Rasbian after upgrade to 5.7.1 #6232
    Windows default folder configuration, which is obviously not working on Linux. After edeiting this it is fine again.
    That’s true.
    in reply to: Runtime Error on Rasbian after upgrade to 5.7.1 #6230
    1) Standard way:
    Uninstall Rapid SCADA according to uninstall.txt and then install the new version.
    However you can try to copy new files overwriting the existing. Don’t forget to register the Agent daemon, it’s important.
    2) It’s easier than earlier. Click the Deployment profile button. Create a new profile, specify your Linux machine in the profile. Upload the project to Linux from Windows computer.
    in reply to: Slave Device Failure #6229
    The register address looks strange. Try address 5-6 instead.
    in reply to: Slave Device Failure #6228
    You can successfully connect to the device. The device “understands” your requests and replies according the Modbus specification:
    Receive (2/2): 84 04
    Device error: [04] SLAVE DEVICE FAILURE!
    https://imgur.com/a/Y8H5iAE
    May be the device can’t get data from sensors?
    in reply to: Runtime Error on Rasbian after upgrade to 5.7.1 #6220
    1) Please provide the details of the question.
    2) Does your project currently work on Windows and you need to upload the project to Linux? Is the project upgraded to 5.7.1?
    3) I suggest configuring on Windows and then upload the project to Linux. To get a computer code, find it in the log of the module.
    in reply to: Slave Device Failure #6219
    Hi Kirjono,
    Please provide screenshots of the Communicator settings and copy a part of log file here.
    in reply to: Runtime Error on Rasbian after upgrade to 5.7.1 #6216
    Try searching for Global.asax in the ScadaWeb folder. There must be only 1 such file.
    May be some old DLLs were not deleted during upgrade. Delete all DLLs in ScadaWeb/bin folder and copy them again.
    in reply to: Runtime Error on Rasbian after upgrade to 5.7.1 #6215
    If you activated RAM drive as written in the installation manual, log files are stored in RAM and don’t exist after reboot.
