Forum Home › Forums › Runtime Bugs › Webstation Bugs › Runtime Error on Rasbian after upgrade to 5.7.1
- This topic has 11 replies, 2 voices, and was last updated 6 years, 6 months ago by
December 17, 2019 at 7:21 am #6198
athes
ParticipantDear Mikhail,
I faced an issue on Raspbian after trying to upgrade from 5.6.x to 5.7.1
I followed the installation guide, but finally after restart I gave the following error message from the webpage ‘myipaddress’/scada/Login.aspx:Application Exception
Runtime Error
A runtime error has occurredDescription: An application error occurred on the server. The current custom error settings for this application prevent the details of the application error from being viewed (for security reasons).
It looks like the communicator working properly, and collected data is continuously storing in the .dat files, but web interface is unavailable.
/opt/scada/ScadaAgent/Log
/opt/scada/ScadaComm/Log
/opt/scada/ScadaServer/Log
/opt/scada/ScadaWeb/log
Logs are error free.What should I try?
December 17, 2019 at 2:22 pm #6202
MikhailModeratorMay be the web application has no access rights to write error in the log.
Try providing full write access to /opt/scada/ScadaWeb/log and its content, restart computer, open the web page, and check the log file for additional information.December 17, 2019 at 3:25 pm #6203athes
ParticipantHi Mikhail,
Thanks for picking this up.
I changed the owner of /opt/scada/ScadaWeb/log from root:root to www-data:www-data.
After reboot it changed back to root:root automatically. Looks like this:
drwxrwxrwt 2 root root 40 dec 17 16:15 log
No logfiles at all in this folder, but I checked an older archive and there were also no logfiles after half a year of running.root@raspberrypi:/opt/scada/ScadaWeb/log# ls -l
Total 0
root@raspberrypi:/opt/scada/ScadaWeb/log#Symptoms remained the same. Runtime error.
December 17, 2019 at 4:44 pm #6204athes
ParticipantI changed the web.config file with adding the parameter <customErrors mode=”Off”/>.
Now I have a more precise error message in the browser:
System.Web.Compilation.CompilationException
CS0433: The imported type `Scada.Web.Global’ is defined multiple timesDescription: Error compiling a resource required to service this request. Review your source file and modify it to fix this error.
Details: CS0433: The imported type `Scada.Web.Global’ is defined multiple times
Error origin: Compiler
Error source file: ~/Global.asax
Exception stack trace:
at System.Web.Compilation.AssemblyBuilder.BuildAssembly (System.Web.VirtualPath virtualPath, System.CodeDom.Compiler.CompilerParameters options) [0x00312] in <0b08341bcdc54df9ae6180034dd611ae>:0
at System.Web.Compilation.AssemblyBuilder.BuildAssembly (System.Web.VirtualPath virtualPath) [0x00008] in <0b08341bcdc54df9ae6180034dd611ae>:0
at System.Web.Compilation.BuildManager.GenerateAssembly (System.Web.Compilation.AssemblyBuilder abuilder, System.Web.Compilation.BuildProviderGroup group, System.Web.VirtualPath vp, System.Boolean debug) [0x00202] in <0b08341bcdc54df9ae6180034dd611ae>:0
at System.Web.Compilation.BuildManager.BuildInner (System.Web.VirtualPath vp, System.Boolean debug) [0x00106] in <0b08341bcdc54df9ae6180034dd611ae>:0
Version Information: 6.6.0.161 (tarball Tue Dec 10 11:12:19 UTC 2019); ASP.NET Version: 4.0.30319.42000December 18, 2019 at 3:59 pm #6215
MikhailModeratorIf you activated RAM drive as written in the installation manual, log files are stored in RAM and don’t exist after reboot.
December 18, 2019 at 4:01 pm #6216
MikhailModeratorTry searching for Global.asax in the ScadaWeb folder. There must be only 1 such file.
May be some old DLLs were not deleted during upgrade. Delete all DLLs in ScadaWeb/bin folder and copy them again.December 18, 2019 at 4:29 pm #6217athes
ParticipantYou felt absolutely right. After deleting and copying DLLs it working fine.
I copied the whole 5.6 system on file level, working perfectly.I need your advice:
1.) How to upgrade on Raspbian to 5.7.1 to not screw up the system
2.) How to migrate config & all from Windows 5.7.1
3.) How to register on Linux the ModAutoControlShould I open one-by-one a thread or can you answer here?
Kind regards,
AttilaDecember 19, 2019 at 12:56 pm #6220
MikhailModerator1) Please provide the details of the question.
2) Does your project currently work on Windows and you need to upload the project to Linux? Is the project upgraded to 5.7.1?
3) I suggest configuring on Windows and then upload the project to Linux. To get a computer code, find it in the log of the module.December 19, 2019 at 1:05 pm #6221athes
Participant1.) I have now a working Linux 5.6 installation. I want to upgrade to 5.7.1, but did not find any documentation how to do that (I don’t want to reinstall the whole Linux and follow the 5.7.1 Linux installation guide – that is really time consuming) — Is there any simple way to upgrade on Linux from 5.6 to 5.7.1?
2.) Yes, I installed on Windows 5.7.1 and I migrated successfully my project. It working perfectly on Windows. I want to move (after point (1) ) to Linux. How to move? I found instructions only for 5.6 win->Linux, but the structure changed in 5.7. I don’t want to create more problems for me 🙂
3.) Thanks, will try.
December 20, 2019 at 2:15 pm #6230
MikhailModerator1) Standard way:
Uninstall Rapid SCADA according to uninstall.txt and then install the new version.
However you can try to copy new files overwriting the existing. Don’t forget to register the Agent daemon, it’s important.2) It’s easier than earlier. Click the Deployment profile button. Create a new profile, specify your Linux machine in the profile. Upload the project to Linux from Windows computer.
December 21, 2019 at 12:17 pm #6231athes
Participant1) Worked fine, thank you.
2) Worked also fine, but it transferred with the Server Common Parameters the Windows default folder configuration, which is obviously not working on Linux. After edeiting this it is fine again.Big thank you for your kind support.
December 22, 2019 at 12:05 pm #6232
MikhailModeratorWindows default folder configuration, which is obviously not working on Linux. After edeiting this it is fine again.
That’s true.
