Elastic report — non clickable link
Forum Home › Forums › Understanding the Software › Elastic report — non clickable link
  • #6252
    athes
    Dear Mikhail,
    I’ve set up Elastic Report as described, but something went wrong:
    The Web interface (http://localhost/Scada/) shows ‘Views/ElasticReport/Sample Report DB’ but I can’t click on it.
    What is the problem?
    I attached a photo about settings.
    https://drive.google.com/file/d/1xpNdkxZ-D9KtbHZ11TmdZOIQlBCW-XIp/view?usp=sharing
    #6257
    Make sure that Elastic Report plugin is activated in Webstation at http://localhost/Scada/plugins/Config/Plugins.aspx
    If it doesn’t help, provide more different screenshots.
    #6258
    After you change Webstation settings, you have to download them into your project. Otherwise, you will override the settings by default when upload configuration.
    #6265
    athes
    I had a lot of play with this, but finally after a webserver restart everything works as expected. Thanks for your kind help.
    #7239
    kcks66
    I have the similar problem. How to do webserver restart?
    #7240
    Open IIS management console and restart web server. Or restart a computer.
