MikhailModeratorDoes PAC3200 use Modbus protocol?
Could you make screenshots related to the issue?
MikhailModeratorDear Han,
Please follow the suggestions written by manjey73. In case of issues, put links to screenshots here.
MikhailModeratorWhat projects have you successfully built before facing the error?
MikhailModeratorYou should download the source code using the link I mentioned in this thread.
MikhailModeratorIs there an easy tutorial to learn how to use Rapid SCADA?
Does Rapid SCADA have the ability to obtain decimal numbers from 64 bit double precision registers
Yes.
What version of Rapid SCADA and Administrator do you use?
I don’t understand error messages in Chinese. Could you translate?
Check this topic. It may help.
MikhailModeratorPlease create a separate topic. This topic doesn’t match the questions.
Also provide an example that demonstrates how a system should behave.
MikhailModeratorThank you for finding the cause. I will fix it in the project.
MikhailModeratorFormula of output channel is calculated in a moment when a command is sent.
MikhailModeratorCan I use ‘Formulas’ also for this purpose?
What purpose?
Does it work in output formula field?
Such formula will work. But CustomFormula() == 1 …
MikhailModeratorwhen some device logon or logoff
How a device do this?
MikhailModeratorEach topic should describe only 1 question.
Please create a separate topic for the second question.
And provide examples for the both cases to make them clear.
MikhailModeratorTry removing ScadaWebCommon5 dependency. Does it help?
You should create a time trigger as usual. Then in the output channel formula, check
Val(101) < -10 ? Cmd : double.NaNdouble.NaN cancels the command.
