MikhailModeratorThe features seems correct. They are identical to my Windows 10 workstation.
If you open http://localhost/Scada/ClientApiSvc.svc , what do you get?
MikhailModeratorChanges have been included in the language pack.
I received the files. Thanks a lot! I will check them and write to this topic.
MikhailModerator
Very interesting!
What kind of tasks are solved by the module?
Does it send the predefined commands in the specified day and time?
Can it send a command once on a particular date?
MikhailModeratorThank you for the solution.
Yes, you can. You should select a camera that provides it’s own web page containing video stream. Also it’s important to disable camera login. Then specify the camera’s web page address into a frame component.
MikhailModeratorYou should check this thread.
May be this cause:
I had exactly the same problem. I found that I had a windows printer setup to use the same port. As soon as I changed the port in the printers settings, the SerialPort.Open() worked.
MikhailModeratorOh, I’ve just realized that not all files were translated.
It should be in C:\SCADA\ScadaWeb\plugins\Table\lang\ScadaTable.xx-XX.xml
start from the line 117<Phrase key="lblAllEventsBtn">All Events</Phrase> <Phrase key="lblEventsByViewBtn">Events by View</Phrase>After changing, logout and login the web app.
If you can fix it, please let me know. And I will add it to the language pack.
MikhailModeratorDo you need to develop a DLL that works as a SCADA-Server module?
MikhailModeratorInstallation of Server application has completed with a error:
Service ScadaServerService hasn’t been installed1. Open command line as administrator
2. cd C:\SCADA\ScadaServer\
3. run svc_install.batWhat messages would you get?
MikhailModerator
MikhailModeratorYou should update Rapid SCADA to v5.8.1 and update the plugins.
Please provide more info how your module should work.
