Forum Home › Forums › Installation Issues › Installation has completed with errors how?
- This topic has 1 reply, 2 voices, and was last updated 5 years, 10 months ago by
August 5, 2020 at 2:46 am #7103
cristianus
ParticipantRapid SCADA 5.8.1 Installation
Create directory C:\SCADA\
Create directory C:\ProgramData\Microsoft\Windows\Start Menu\Programs\SCADAInstall Server application
Unzip files from D:\Rapid SCADA\Arc\ScadaServer.zip
Install service ScadaServerService
Process completed with an error
Installation of Server application has completed with a error:
Service ScadaServerService hasn’t been installedInstall Communicator application
Unzip files from D:\Rapid SCADA\Arc\ScadaComm.zip
Install service ScadaCommService
Installation of Communicator application has completed with a error:
Service ScadaCommService hasn’t been installedCheck the configuration of Internet Information Services (IIS)
Go to
Control Panel > Programs > Turn Windows features on or off
and make sure that WCF Services > HTTP Activation feature is installed for .NET Framework 4+,
whereas the components for .NET Framework 3.5 are switched off
Check Windows Communication Foundation (WCF)
Register ASP.NET
Install Webstation application
Unzip files from D:\Rapid SCADA\Arc\ScadaWeb.zip
Selected application pool: DefaultAppPool
Register web application Scada
Create shortcut Webstation
Installation of Webstation application has completed successfullyInstall Agent application
Unzip files from D:\Rapid SCADA\Arc\ScadaAgent.zip
Install service ScadaAgentService
Installation of Agent application has completed with a error:
Service ScadaAgentService hasn’t been installedInstall Administrator application
Unzip files from D:\Rapid SCADA\Arc\ScadaAdmin.zip
Create shortcut Administrator
Installation of Administrator application has completed successfullyInstall Scheme Editor application
Unzip files from D:\Rapid SCADA\Arc\ScadaSchemeEditor.zip
Installation of Scheme Editor application has completed successfullyInstall Table Editor application
Unzip files from D:\Rapid SCADA\Arc\ScadaTableEditor.zip
Installation of Table Editor application has completed successfullyInstallation has completed with errors
Please restart the computerAugust 5, 2020 at 4:30 pm #7104
MikhailModeratorInstallation of Server application has completed with a error:
Service ScadaServerService hasn’t been installed1. Open command line as administrator
2. cd C:\SCADA\ScadaServer\
3. run svc_install.batWhat messages would you get?
- The topic ‘Installation has completed with errors how?’ is closed to new replies.
