Realtime data get and set value
Forum Home › Forums › Development and Integration › Realtime data get and set value
  • #7093
    minhnt152
    I want to develop a server side block programming for automation. I want to access the real-time value and command to the tag. Which library I should use to access to the real-time data?
    Regards
    #7096
    Please provide more info how your module should work.
    #7102
    minhnt152
    I have tried the open module code that copy the value from an input channel to a output channel and it works.
    My aim is to create a block programming at server side, to work similar to the Automation module.
    #7105
    Do you need to develop a DLL that works as a SCADA-Server module?
    #7111
    minhnt152
    Thanks i made it 🙂
