Forum Home › Forums › Installation Issues › SCADA-Web Installation › Scheme loading failed. Try to reload scheme
- This topic has 13 replies, 2 voices, and was last updated 6 years, 2 months ago by
August 9, 2020 at 11:54 am #7122
gasin
i’m install rapid scada 5.8. When i open webpage via localhost, it will show message “Scheme loading failed. Try to reload scheme” and scheme graphic that i create did not show.
i try to reinstall again and did not create any project. i use demo project but the problem was still the same “Scheme loading failed. Try to reload scheme”. And Events tab will show “Error update Events”.
How can i solve this problem? Please suggest.
August 10, 2020 at 6:53 am #7125
MikhailModeratorAugust 10, 2020 at 12:08 pm #7128gasin
Participanti try as you suggest but problem still occur.
i try to uninstall/reinstall iis and select same as your link detail but can solve problem.
Problem was the same. When i open webstation, it will show error both scheme and table pages.
i check my iis and see that it use asp.net 4.8. i don’t know is this a problem for this? I try to run aspnet_regiis.exe -i and it show “This option is not supported on this version of the operating system.”. i use window 10.
Any suggest for this problem.
here is my selection when install iis.
August 10, 2020 at 1:22 pm #7129
MikhailModeratorThe features seems correct. They are identical to my Windows 10 workstation.
If you open http://localhost/Scada/ClientApiSvc.svc , what do you get?
August 10, 2020 at 3:35 pm #7130gasin
ParticipantThe result after open http://localhost/Scada/ClientApiSvc.svc
“This localhost page can’t be found
No webpage was found for the web address: http://localhost/Scada/ClientApiSvc.svc
HTTP ERROR 404”.August 11, 2020 at 11:21 am #7131
MikhailModeratorIs there a file C:\SCADA\ScadaWeb\ClientApiSvc.svc ?
August 12, 2020 at 7:02 am #7136gasin
Participantyes, it has this file on C:\SCADA\ScadaWeb\
August 12, 2020 at 1:27 pm #7141
MikhailModeratorTry uninstalling the item “WCF Services” and then installing again.
August 14, 2020 at 11:29 am #7164gasin
ParticipantYes, i try to remove all .Net framework 3.5 and 4.8 and iis setup on “Turn window on or off” then reinstall again. But problem still occur.
August 14, 2020 at 2:54 pm #7165
MikhailModeratorIn what sequence do you install all of them after removing?
August 15, 2020 at 2:24 pm #7168gasin
ParticipantI install .NetFramework at first and then iis.
August 16, 2020 at 7:12 am #7170
MikhailModeratorTry uninstalling only the item “WCF Services” and then installing again.
August 16, 2020 at 3:11 pm #7171gasin
Participantok, i done as you suggest and now it’s work.
thanks.
August 17, 2020 at 4:43 pm #7173
MikhailModeratorThis was the last guess ))
