Viewing 15 posts - 3,301 through 3,315 (of 6,219 total)
  • in reply to: ScadaAdmin on Linux #7933
    sudo mono ScadaAdmin.exe
    It’s possible to run the Administrator app on Linux. But it has many restrictions because Mono Windows Forms are not really supported. And they have no future. I suggest editing projects on Windows and then upload to Linux.
    Rapid SCADA 6 Administrator will be ported to .NET 5, so it will be impossible to run it on Linux. Of course, Server, Communicator and Webstation will work on Linux. There several way that are open to edit projects on Linux in the future:
    1. Avoid editing projects on Linux ))
    2. Microsoft wrote about merging WPF and Xamarin Forms. So when they do this, it would be possible to develop cross platform desktop Administrator.
    3. Develop full featured web Administrator and deprecate the existing desktop Administrator. It requires a lot of efforts.
    4. Develop lightweight web Administrator for professionals and keep existing desktop Administrator up to date.
    in reply to: Virtual Keyboard #7932
    I agree that virtual keyboard would be useful. And some users asked about it. In my opinion, virtual keyboard should not be a part of a particular web application. Probably it should be a browser extension or a native application of an OS. For example, like keyboard in Android and Windows.
    However, it’s also possible to develop a plugin for the Webstation app that implements a keyboard.
    in reply to: Transfer File from Computer to Rpi #7924
    I know how to create new deployment profile, but set parameters correctly aren’t clearly.
    If something doesn’t work, make screenshots of your deployment profile settings.
    in reply to: Transfer File from Computer to Rpi #7911
    In your project open Server – Common Parameters and update directories. You can click “Default for Linux” there.
    Then use the above advice.
    Do you know how to create a new deployment profile?
    in reply to: ChartPro Colors are gone #7910
    Good 🙂
    in reply to: Continuing a calcuation after restart ? #7909
    If you use RAM disk for current data on Raspberry, it will not be saved on hardware reboot. If you write scripts for your solution, it would be good.
    in reply to: Modbus RTU comunication issue #7908
    If you use GSM modems, you can try a mode when Communicator is TCP server, and a modem is TCP client, so a modem doesn’t need static IP address.
    in reply to: ChartPro Colors are gone #7901
    1. Press Ctrl+F5 in browser to update cached scripts.
    2. Check if C:\SCADA\ScadaWeb\config\PlgChartPro.xml exists. This file also must be included in the project.
    in reply to: Continuing a calcuation after restart ? #7899
    Check the following:
    1. Stop the server service.
    2. Open current data and check value of the channel 1311. Use Administrator to view raw data. Does it correct?
    3. Start server. Check value of the channel 1311 again. What is the value and status?
    4. If it was reset, publish ScadaServer.log.
    Provide some screenshots.
    • This reply was modified 5 years, 3 months ago by Mikhail.
    in reply to: Communication Line Request Sequence not Saving #7898
    This bug is really strange. You are the first who faced it. Could you provide some screenshots to show the sequence of steps before the problem?
    in reply to: RSAdmin: Browsing Archive is only locally. #7894
    We can continue if you provide screenshots.
    in reply to: Rising Event with user defined Event type #7893
    Before checking Auto Control Module, we need to know what channel values and statuses are really calculated.
    in reply to: Rising Event with user defined Event type #7892
    Open data files remotely is not a good solution, because they might be too big. I think we should add a web viewer that displays raw data.
    in reply to: Rising Event with user defined Event type #7891
    Since I can’t open the any log under Server/Archive/ from RSAdmin
    If you mean current or historical data, use ScadaDataTest utility.
    in reply to: Rising Event with user defined Event type #7890
    You can open logs from text files in any time.
    After sending a new value using Generator, check the actual channel data
    Administrator – Instances – Default – Server – Archive – Current Data
    If the channel data differs from the expected, let me know what channel data was expected and what is the actual result.
