ChartPro Colors are gone
Forum Home Forums Runtime Bugs Webstation Bugs ChartPro Colors are gone
  • #7896
    athes
    Hi Michail,
    After upgrading from 5.7.1 to 5.8.2, and using the latest ChartPro 5.1.0.1 my charts lost their colors.
    Running on Linux/Raspberry Pi.
    Example: https://drive.google.com/file/d/18Oy8zQISFwwe-EL-lAMALzenAvGtao0D/view?usp=sharing
    What should I check to fix this issue?
    #7901
    1. Press Ctrl+F5 in browser to update cached scripts.
    2. Check if C:\SCADA\ScadaWeb\config\PlgChartPro.xml exists. This file also must be included in the project.
    #7902
    athes
    Hi Mikhail,
    Thanks, point 2 was the issue: I’ve copied it during the upgrade, but was missing from the project. After the firs upload I assume it was deleted from the /opt/SCADA/ScadaWeb/config/ path.
    Now it works as designed. 🙂
    #7910
    Good 🙂
