Communication Line Request Sequence not Saving
Forum Home › Forums › Communicating with Devices › Communication Line Request Sequence not Saving
  • #7845
    yotool
    Hello Mikhail,
    I recently did a completely fresh install of Rapid SCADA v. 5.5.2.0.
    The goal was to reproduce a known MODBUS-TCP configuration used on a different computer being retired.
    For some reason I cannot get the Administrator application to “Save” the Request Sequence information. It is always lost even after UPLOADING a saved configuration.
    The Communication Lines/Line Parameters/”Request Sequence” row is saved but the associated xml “Request sequence” information itself is lost each and every time I leave the configuration screens (even after making sure to UPLOAD the request sequence changes to the server).
    When I return to the Request Sequence edit screen and hit the “Properies” [sic] button, the Administrator application always presents me with the default “KpModbus_NewTemplate.xml”(empty) request sequence information. The actual edited/saved .xml configuration file IS saved as a text file in the project folder, but its filename is NOT placed in the “Command Line” field and its association with the “Request Sequence’ row saved to the configuration database is always lost. Even if I manually place the name of the newly edited xml file in the “Command Line” field, save the config to the database, and then come back to editing the communication line, when I hit the “Properies” button, I am again presented with empty “KpModbus_NewTemplate.xml” XML (via GUI) file contents.
    Any ideas?
    Thanks for your help.
    https://photos.app.goo.gl/7m9MoTyGm1ig95yBA Communication Line Command Line/Request Sequence Not Saving
    • This topic was modified 5 years, 11 months ago by Mikhail.
    #7851
    Could you update Rapid SCADA to the up to date verion 5.8.2? May be this problem will be solved by the update.
    #7854
    yotool
    Sorry, it appears that I DID download and install the latest version of Rapid SCADA 5.8, but when I looked for the version I had installed before posting this issue, I used the “About” button for the “Administrator” sub-application which displays 5.5.2.0.
    The installer/uninstaller does show v.5.8.
    • This reply was modified 5 years, 11 months ago by yotool.
    #7863
    Administrator 5.5.2.0 is included in Rapid SCADA 5.8.0, but the current version is Rapid SCADA 5.8.2. See the version history for the details.
    #7878
    yotool
    Acknowledged.
    I could not find any way to easily determine which version of Rapid SCADA is installed. Might be nice to have the “About” feature of the Administrator application show the versions of the overall product as wells as the modules. Just a thought.
    In any case. I DO have the latest version of Rapid SCADA installed and this does appear to be a bug in version 5.8.2. Would be interested to know if you, or another, can replicate the issue on your end.
    I UNinstalled v.5.8.2, INSTALLED 5.7.1, which I had downloaded some time ago, and the problem is gone.
    Many thanks.
    #7888
    Rapid SCADA contains many applications. A user can upgrade them separately. The easiest way is to keep the downloaded installation package.
    #7889
    5.7.1 is too old. I suggest to install v5.8.2 that includes Administrator 5.5.2.1.
    #7897
    yotool
    Yes, agreed but then we are back to the beginning of the issue where this “not saving/associating the Request-Sequence XML file (template) with a device” problem appears to exist with the “latest” version v5.8.2 of Rapid SCADA.
    If anything, just curious to know if you can reproduce the issue I am seeing in v.5.8.2.
    Thanks.
    #7898
    This bug is really strange. You are the first who faced it. Could you provide some screenshots to show the sequence of steps before the problem?
