Viewing 15 posts - 3,166 through 3,180 (of 6,219 total)
  • in reply to: ChartPro Export to Excel #8311
    Hi Rich,
    I only have Libra office not MS Excel , is this an issue ?
    No. The cause is in Rapid SCADA.
    Please open a list of installed plugins and check that Chart Plugin (not only Chart Pro) is also active. It is important to load phrases from PlgChart.en-GB.xml
    in reply to: Initial setup issues #8310
    2021-02-21 14:51:45 Error executing actions of Device 41 “Email sender” on communication line start: Error loading device settings:
    This issue is not related to Modbus, but to the email sending driver.
    To fix:
    1. Download the driver update
    2. Configure email sending.
    In case of errors, post screenshot links to this topic.
    in reply to: ChartPro Export to Excel #8306
    What version of Webstation and Chart Plugin do you use?
    in reply to: ChartPro Export to Excel #8305
    Restart web server, open a report, and copy all lines from the log starting from
    “Initialize common web application data”
    in reply to: Can not activate Extra component plugin. #8304
    Use WinSCP
    in reply to: Can not activate Extra component plugin. #8301
    On Linux machine you should provide write access rights to /opt/scada/ScadaWeb/config directory.
    After you upload the project, the rights may be reset again. We will fix it in the future.
    in reply to: ChartPro Export to Excel #8300
    This report is included in Chart Plugin which is installed by default.
    Also check existence of C:\SCADA\ScadaWeb\plugins\Chart\lang\PlgChart.en-GB.xml
    and errors in C:\SCADA\ScadaWeb\log\ScadaWeb.log after computer restart.
    in reply to: Rapid SCADA tite text #8297
    Hi Matt,
    You can change it in ScadaData.*.xml
    <Phrase key="ProductName">Rapid SCADA</Phrase>
    in reply to: Silent server crash #8296
    does the above update also applied for linux version?
    Yes. It’s enough to update the *.dll files. ScadaServerMono.exe is just a shell to run the app.
    in reply to: ChartPro Export to Excel #8295
    Please provide a screenshot.
    in reply to: ChartPro Export to Excel #8291
    1. Yes, in the data panel there are only channel numbers.
    2. Something wrong with a language file. What language do you use in Webstation?
    in reply to: ChartPro Links #8289
    This answer may help.
    in reply to: New device drivers #8287
    OK
    in reply to: New device drivers #8284
    An article
    Driver examples
    To debus a DLL, you need to attach to the process that uses the DLL. In case of drivers, attach debugger to ScadaComm.exe
    in reply to: Cannot see installed schemes extra components module #8281
    Probably the access rights return to defaults when you upload the project. I suggest editing web app settings via XML file in Administrator. In the future all settings will be edited using Administrator UI.
