Viewing 15 posts - 3,151 through 3,165 (of 6,219 total)
  • in reply to: rapidgate module bug #8353
    Parameter name: format
    It is related to string formatting. May be language files were not loaded and a required string is empty. Anyway, log files are needed.
    in reply to: rapidgate module bug #8352
    Please provide bigger part of ScadaServerSvc.log and ModRapidGate.log which are located in C:\SCADA\ScadaServer\Log
    in reply to: get line state #8351
    Currently, getting line and device state is not supported. You need some workaround.
    It can be a good idea for the future.
    What information do you need to extract?
    i use gate module to send data between them
    Rapid Gate was updated on December 14, 2020. Do you use the latest version?
    i write an big screen project to show tcp state and line state.
    Could you share screenshots?
    in reply to: Any questions about Rapid SCADA and Raspberry Pi #8336
    in reply to: Server is unavailable #8335
    I don’t recommend using Administrator on Linux. It works well only on Windows. You can upload a project from Windows to Linux.
    1. Export the Users table into user.dat. Administrator – File – Export Table
    2. Manually copy user.dat to /opt/scada/BaseDAT
    If the problem still exists, see /opt/scada/ScadaAgent/Log/ScadaAgent.log for the details
    in reply to: l #8328
    Demand: Hope the button plugin supports pressing (set 1) and pop up (set 0) operations
    If you mean 2 state button, like a toggle switch, use dynamic picture or toggle component.
    in reply to: l #8327
    Demand:Pass input and output parameters to the calling page through the link plugin
    When you specify ViewID to navigate by a link component, input channels are ignored.
    To use input channels as parameters, set ViewID=0 and set the URL property. For example, mypage.html?param1={0}&param2={1}
    where {0}, {1} are the indexes of the specified input channels.
    A button component supports only sending commands and opening charts. To open a popup use link component. You can change link properties to display it in button style.
    If you open the same view by clicking the explorer tree node, does it work correctly?
    The operation button plugin has only close and open functions, no other button functions can be configured, as shown in Figure 4:
    Buttons for a command can be specified by editing the Output channel table of the configuration database.
    in reply to: Scada Agent error #8326
    You need Mono version 6. Installation instructions are here.
    in reply to: Scada Agent error #8322
    Please check the version of Mono Framework by the command
    mono --version
    in reply to: Map Plugin question #8320
    If status channel is specified, there 3 colors as you described: gray, red and green.
    It’s limited because a marker is a static image loaded from file.
    It would be nice if a location pin/tag can follow the status color of a chennel, like other components.
    When click on empty location, it shows Geo Latitude and longitude. is it possible not to show it?
    I wrote these items into the request list.
    Currently, it’s possible to disable popups manually by editing map.js file.
    in reply to: Scada Agent error #8316
    If the files presented, try the command line
    mono /opt/scada/ScadaAgent/ScadaAgentMono.exe
    in reply to: Scada Agent error #8315
    Looks like the Agent application was not installed on RPi. Are there any files in /opt/scada/ScadaAgent directory?
    in reply to: ChartPro Export to Excel #8314
    Hi Rich,
    Changes of the report are possible, but require custom development.
