Viewing 15 posts - 2,971 through 2,985 (of 6,219 total)
  • in reply to: MQTT #8863
    About the formulas:
    You should change channel type to “Real”. In this case, formulas are calculated when new value is coming from a controller or MQTT broker.
    in reply to: Views #8860
    Could you provide links to the screenshots? Screenshots are more clear than text descriptions, so we could find the solution faster.
    in reply to: MODBUS TCP CONNECTION #8859
    OK 🙂
    in reply to: MQTT #8858
    Note: the MQTT driver update is coming soon. The driver will support generating of input channels according to the configuration, and JSON parsing will be improved.
    in reply to: MQTT #8857
    As you can see on my images I have two formulas
    I don’t see any images that contains formulas. If you add them, I will check.
    Value is all the time the same as in communicator
    As wrote above, the result of formulas can be displayed by views, not in Communicator.
    I also noticed that Rapid SCADA takes quite some time to read data from Mqtt broker. When around 80 variables is published to Rapid SCADA it takes more then 1 minute to show all the data.
    Could you provide more info about that?
    If we choose Rapid SCADA for our projects can we count on official support or is Mqtt community developed and so unofficial?
    We also support the existing MQTT driver.
    in reply to: Views #8851
    I recommend to update the file structure on disk as you need to show in the tree
    Root
      SiteA
        NewFile.sch
    In the title column just enter simple titles.
    You can also set Title = Root\SiteA\Option1 but it’s not clear when not reflects file structure.
    in reply to: MQTT #8850
    Is it possible to use formulas for input channels that are using MQTT?
    Formulas are processed on the Server application level and they do not depend on a driver.
    The result of formulas can be displayed by views, not in Communicator.
    in reply to: Initial setup issues #8849
    That’s mean i can not configure the device that can send email to group_name.7
    It duplicates another topic.
    in reply to: Email device Can not send email to group_name #8843
    Please try the updated version of the driver.
    In case of similar error, it can write more info in the log that helps to find the cause.
    in reply to: Automatic Control Module command disabled #8839
    Try selecting a command node in the tree. If it doesn’t help, provide links to screenshots.
    in reply to: Registration Problem #8837
    Please contact us by email.
    in reply to: Export to DB PostgreSQL #8836
    DB export module executes only 1 request per operation. If you need to execute many requests, wrap them by stored procedure on the DB side.
    in reply to: Communication Line bound to server signal limitation #8832
    Share the results please.
    in reply to: Bulk Creation of Devices and Communication Lines #8831
    It’s possible to generate XML as specified above in Excel.
    in reply to: Forced Modbus TCP reconnect after serial error. #8830
    The described behavior is programmed. Probably, it should be configurable in the communication layer properties.
