Viewing 15 posts - 2,851 through 2,865 (of 6,219 total)
  • in reply to: how to add admin user to scadaweb in Linux #9227
    You should edit a project on Windows by the Administrator application and then upload the project to Linux server.
    in reply to: FX2N-20MR chinese semi-clon of a Mitsubishi PLC #9224
    I wonder if I can make a simple SCADA system using that port and just one computer running this software and Windows 7 or Xubuntu version 20.
    If the PLC support Modbus communication protocol, you can use it with Rapid SCADA. You need to know Modbus register map that contain Modbus addresses to poll.
    in reply to: System requirements #9223
    Hi Marcelo,
    System Requirements
    RAM and disk space highly depends on your particular system.
    I suggest 4 GB RAM at least.
    in reply to: dbexport module affect the command #9206
    Those settings are https://rapidscada.net/doc/content/latest/en/modules/mod-db-export-files/db_export_manual_en.png
    Anyway, there will be new fully redesigned DB export module in the next version.
    in reply to: dbexport module affect the command #9203
    DB Export module has some output channel in its settings. Check that they are not interfered with your Modbus output channels.
    in reply to: cunstom page develop #9201
    This example may help.
    in reply to: Signal Relative ID to Fixed ID ? #9200
    Do you mean changing datatype of each element in a group?
    in reply to: Administrator Channel pane on LInux #9199
    The primary ideas are kept the same. API changed.
    in reply to: cunstom page develop #9193
    if there are too many channels there will be an error with HTTP requests with method GET
    How many channels can be requested without error?
    Probably you should split one big request to a set of smaller requests.
    To request channels of a view, the view should be loaded in server part of the web app as you did. But it’s not clear solution.
    Or could we change the method GET to POST?
    Using C# you can develop a plugin that provides any API in comfortable format.
    • This reply was modified 4 years, 9 months ago by Mikhail.
    in reply to: Signal Relative ID to Fixed ID ? #9192
    I was wondering why not use starting adress as the signal id
    Talking about Modbus, starting address can be the same for Coils and Holding Registers, for example.
    I think, we will improve Modbus Template Editor to simplify manual operations.
    in reply to: Administrator Channel pane on LInux #9189
    Currently Rapid SCADA uses Mono on Linux.
    Mono is OK for everything that related to logic processing and web application.
    But Mono GIU apps, like Administrator, work bad on Linux.
    In the next version Rapid SCADA 6 we will use .NET5 instead of Mono Framework, both on Windows and Linux. Administrator on Linux will not work. You should edit projects on Windows workstation and upload them to Linux server.
    If we find a sponsor, we can develop Web Administrator for any platform.
    in reply to: SCADA V6 #9182
    Looks good.
    If it’s not related to the topic subject (version 6), please post such messages to another or new topic.
    in reply to: Signal Relative ID to Fixed ID ? #9181
    Rapid SCADA will support string tag codes instead of numbers in version 6. It will allow to avoid such problem.
    in reply to: IEC61107 Protocol driver #9180
    It’s an English language forum. Messages on all other languages will be deleted. Use forum.rapidscada.ru
    in reply to: Administrator Channel pane on LInux #9179
    Using Administrator on Linux is deprecated and should be avoided. Microsoft killed this path.
