dbexport module affect the command
Forum Home › Forums › Runtime Bugs › dbexport module affect the command
  • #9202
    Zeus
    hi,
    Yesterday I use the module DbExport. If I make it work. the Modbus command will be canceled on the server. If I canceled the module DbExport. the command works right.
    #9203
    DB Export module has some output channel in its settings. Check that they are not interfered with your Modbus output channels.
    #9204
    Zeus
    hi,
    Should I config the input channel to fill the output channel grid with the output channel number?
    I checked the DB Export module. I only configured the current data export with SQL below.
    INSERT INTO cnldata (datetime, cnlnum, val, stat)
    VALUES (:dateTime, :cnlNum, :val, :stat)
    The database is Oracle 11g and I changed SQL ‘@val’ to ‘:val’.
    My version is 5.8.2 and I don’t find any grid to config the DB Export module output channel settings.
    #9205
    Zeus
    hi,
    I changed the code.
    https://ibb.co/Z8csbW0
    In the DB Export module. If we received the command and we enable current data export. passToClients is always false. and the device could not receive commands. the command is canceled. and only the command type BaseValues.CmdTypes.Binary is handled.
    I don’t know why we cancel it if we use DB Export module.
    #9206
    Those settings are https://rapidscada.net/doc/content/latest/en/modules/mod-db-export-files/db_export_manual_en.png
    Anyway, there will be new fully redesigned DB export module in the next version.
