MikhailModeratorif (Cnl=65535) return 0;has wrong syntax. C# uses == as equality operator.
Please provide clear description of the issue.
“Real” channels are measured by devices.
“Calculated” channels are calculated based on real channels.
To display status as a number, useStat(102)formula.
Using too many channels in a one view will be slow and not comfortable for an operator.
Please provide screenshots that explain your question.
Probably there should be another report for current data. I will add it to the wish list.
If Communicator cannot connect to the Server app, make sure that Server is OK.
I’ve updated Application Protocol 3.0.pdf
Use ScadaTestClient-v6.zip from this folder to test getting file info.
I will check why file length is 0.
MikhailModerator2022-11-16 15:16:52 [wst1][appstack][ERR] Error calling the Start method of the MqttServer data source: System.InvalidOperationException: Collection was modified; enumeration operation may not execute. at System.Collections.Generic.List 1.Enumerator.MoveNext() at Scada.Comm.Engine.CommLine.SelectDevices() at Scada.Comm.Drivers.DrvDsMqtt.Logic.MqttDSL.FillDeviceTopics() at Scada.Comm.Drivers.DrvDsMqtt.Logic.MqttDSL.Start() at Scada.Comm.Engine.DataSourceHolder.Start()Does this error appear every time when you restart Communicator?
MikhailModeratorTo enter correct options, use the Administrator app.
MikhailModeratorInfluxDB can be used for historical archives only. It doesn’t work with current data and events.
For example, I use the following options for InfluxDB archive:
Connection = InfluxConn Deadband = 0.1 DeadbandUnit = Absolute IsPeriodic = false LogEnabled = true PullToPeriod = 0 ReadOnly = false Retention = 365 WriteOnChange = true WriteWithPeriod = true WritingPeriod = 1 WritingPeriodUnit = MinuteYou should configure a connection.
If you add thousands of devices, especially with master-slave polling, you may face network performance issues that should be solved individually.
2022-11-18 16:48:13 [SCADA6][SCADA6$][ACT] Webstation 6.0.0.0 started ... 2022-11-18 16:48:18 [SCADA6][SCADA6$][INF] The application is ready for operatingIt takes 5 seconds, which is good. The web app is started when a request is initiated by a browser, so you need to click the refresh button after uploading configuration.
This behavior is on Windows. Linux web service does not need user action.
I would like to know which operator did it for example between “user” or admin.
Currently, there is no such function. However, it can be developed.
