MikhailModeratorTo check Mono version, run the command
mono --version
Can the Webstation and Administrator applications start successfully?
Copy the following files to RPi:
/opt/scada/ScadaServer/Mod/ModAutoControl.dll
/opt/scada/ScadaComm/KP/KpEmail.dll
/opt/scada/ScadaComm/KP/KpTelegram.dll
Do you use Rapid SCADA 5 or 6?
Please let the community know about the result.
If you have not purchased cameras, you could choose a camera model that provides video for web.
In the communication line log, there is an error on loading the Email Driver settings.
You should check that the driver version on Windows and on RPi are the same. Use the up to date version.
The customer uses cameras that provide video in the RTSP format.
RTSP is not supported by web browsers directly. Therefore the customer uses Unreal Media Server to convert video streams into a HTML5 friendly format.Many cameras support HTML video out of the box. I cannot provide particular camera model, because there are thousands of cameras on the market. A camera’s manual should say that it can display video in browser.
After you install and run Telegram Driver on RPi, you will find a computer code in a communication line log. To install the driver, copy the driver’s DLL into /opt/scada/ScadaComm/KP
The above video is not displayed because it was removed from YouTube. You should find active live channel to check.
Question about streaming video from camera is discussed here.
Telegram is a driver that works with Communicator. Webstation version is not important. I recommend to update Rapid SCADA at least to the version 5.8.4.
MikhailModeratorDear Han,
KpSms.dll of any version supports Huawei e1750
MikhailModeratorThank you for the screenshot.
I’ve added this issue in the list. Will think how to solve it.
Copy DrvTelegram.Logic.dll into /opt/scada/ScadaComm/Drv
Copy DrvTelegram.View.dll into SCADA\ScadaAdmin\Lib on Windows
Copy driver’s language files into SCADA\ScadaAdmin\Lang on Windows -
