manjey73Participantservice scadaserver6 start
or
systemctl start scadaserver6.service(restart, stop, status)
(scadaagent6, scadacomm6, scadaweb6)the rest is by analogy
Check for uwf on the remote Ubuntu machine. This is another firewall that can block your access
manjey73ParticipantFlies separately, cutlets separately 🙂
manjey73ParticipantNo. .your pem key is used to access the remote server via ssh.
To transfer the project from the Administrator, you need to open TCP port 10002 for ScadaAgent to work. Configure the firewall accordingly.The secret key and passwords in Scada are already internal protection methods so that third-party Scada Administrators cannot connect to your Scada Server and change the data.
manjey73ParticipantThe Ubuntu server can be remote with a real IP address (for example, on a VDS server) or connected to your server via VPN.
And there is also an option when the Scada Agent connects via proxy mode. There are many connection options.
manjey73ParticipantYes, when you debug a project on a local PC, you can transfer it to a production Server by specifying its IP already. And the browser is already open on the remote PC, if the WEB server is located there.
manjey73ParticipantIn the deployment profile, specify where to transfer the project. Specify the IP of your Ubuntu server there instead of localhost
This reply was modified 2 years, 1 month ago by
manjey73.
manjey73ParticipantCheck if the ScadaAgent6 service is running
manjey73ParticipantHere I used to import a function from the library for the driver of the 5th version of scada.
By itself, the import probably will not be different for version 6, there are differences in the construction of the driver itself.https://github.com/Manjey73/OpnenKPs/blob/master/KpRpi3/KpRpi3/WiringPi.cs
Oh, well, here’s an example for the Linux library.
manjey73.
manjey73ParticipantC# allows you to use a dll in C if all the necessary functions are exported in the C library. Probably the best approach would be to write a driver for RS that will work with your C libraries and load data directly into the scada database.
There are examples of how to use the C library in the RS driver. If necessary, I will give you links.
manjey73ParticipantHow do you receive data via the COM port?
August 27, 2024 at 5:48 am in reply to: RS5 Interface and Config db must be common for all deployed Instances? #15236
manjey73ParticipantYou have one Server database. Instances are required in the current version for remote Communicators.
If you need different Server databases, you should have several projects, not one.
manjey73ParticipantOne person cannot do everything at once. 🙂
manjey73ParticipantThere are many newcomers here, but this does not prevent sharing :).
Write what do you want to implement, a driver, a module, a plugin? they will always help with one or the other here. One problem, many people communicate through an online translator.
manjey73ParticipantThis will already be a significant contribution. Plus the purchase of existing paid functionality from the developer.
