In theory, you can make a recipe with arrays of data plus a selection formula. And also with the help of an automatic control Module.
For example, you make an array for a recipe that you will send to the device using the module. As well as several arrays for storing your recipes. A calculated selection channel that, at different values, copies from the storage array to the current recipe array. With the automatic control module, you control the change of the main array and send it to the device or panel.
This reply was modified 2 years, 10 months ago by
manjey73.
