manjey73ParticipantFor example, you get a value from the Communicator that needs to be handled differently from the channel boundaries. The status in the normal state will always be =1, you use control based on other criteria and change the status to your own, respectively, adjust the status mask for displaying and controlling output to Events.
manjey73ParticipantYes, you can only enable “Status changed”
and, depending on the destination, use monitoring and status change in the second part of the input formula.
Channel formula:status formula
manjey73ParticipantChannel data – value or status
<Option name=”EventCount” value=”100″ />
in ScadaWebConfig.xml
manjey73ParticipantUse an Event Mask
I can’t think of anything else.
manjey73Participanttry to split the parameters into two devices, mydev1.1 and mydev1.2, and specify the second as command reading in the Communicator settings. well, and link the team.
manjey73ParticipantStep 1 – Create an archive in Instances – Default – Server – Archives
Step 2 – add the created archive with the bit indication to the secondary tableWritingPeriod – The recording period starts from 1 second
This reply was modified 3 months, 1 week ago by
manjey73.
July 14, 2026 at 9:04 am in reply to: Archive Mask and Select Archives – How are they related? #18143July 14, 2026 at 9:00 am in reply to: Archive Mask and Select Archives – How are they related? #18142
manjey73ParticipantThe presence of checkboxes should be present when you click on the Archive Selection with the specified mask.
I didn’t check, maybe you set the archive, but didn’t assign it a bit for the mask, as a result of which you lose the checkboxes? But in theory, if the bit is not assigned, then it will simply be missing from the list when selecting the archive in the channel.
manjey73Participantif the devices are the same, one is configured, then cloning with an indication of the device change. But if the devices are different, then we have sailed to manual labor 🙂
manjey73ParticipantThe Mimic plugin must be fully installed on a PC with an Administrator. Since the Editor runs the WEB for editing, it should be on your PC as well.
manjey73ParticipantAccording to the rules of the Modbus package, the lowest byte is indicated first, and the highest byte is indicated last. But that doesn’t mean that the meaning has suddenly changed, does it?
manjey73ParticipantI am trying to embed a webpage from another device in one of my mimics, is the dashboard plugin the only way to do so?
frame in extended Mimic components
Just connect your entire page.
manjey73ParticipantThe image does not have properties that can be passed a value so that the image can be changed according to the condition. I don’t remember if it’s possible to specify the control channel directly in the Picture.
But you can change the file name property of the image inside the faceplate using the component script or facplate.
I haven’t gotten to the continuation of how to do this yet 🙂
manjey73ParticipantIf I’m not mistaken, but the conditions are not transmitted to the Image installed in faceplate.
manjey73ParticipantAs far as I know, you just need one network, ports are not important. This is how I connected to devices with virtual network addresses, but I had to be a client of this network.
