Installation Rapid Scada on Windows Server 2016
Forum Home › Forums › Installation Issues › SCADA-Web Installation › Installation Rapid Scada on Windows Server 2016
  • #17715
    oldwizardkz
    I need help to install Rapid Scada on Windows Server 2016. In instruction it need to install ASP .Net Core module, but i cant install it directly. It’s can only install from Windows Server Manager. But i cant find that module in list of Server Manager.
    #17720
    Definitely Rapid SCADA can be installed on Windows Server 2016.
    Step 1: Install and Configure IIS Role.
    Step 2: Install the .NET Hosting Bundle.
    If it is not enough, let me know.
    #17723
    oldwizardkz
    Hello. Thanks for reply. I find solution.
    First need to install Web Server (IIS) in Server Roles. In list of Web Server features check ASP, ASP.NET 4.6 and Websocket Protocol. Then install ASP.NET core Hosting Bundle and reboot PC/Server/VM. After that SCADA can work correctly and you can see graphics in web browser.
    #17725
    Thank you for sharing the solution.
