elee
ParticipantWhat is the best way to return the entire scada application to the default and start the plugin installation over again?
This is the point I am at, the ScadaWeg.log shows that the plugins are found and registered. All of the files are in the appropriate locations. I have lost the extra shapes that previously work, the extra mimic components never worked.
elee
ParticipantLine 2 has TCP connection timeout errors, how can I optimize this line? There are 4 snmp devices. I can move one to modbus (line 1), as that device has both options, the others do not. What is the maximum number of devices per line?
Is it fair to assume that each communication line should have all devices of that driver type assigned?
Line 2 Main Options: (program defaults)
request retries on error – 3
delay after polling cycle – 0
TCP Client, reconnectAfter = 5Line 2 Custom Options:
TansMode = TCPLine 2 Device Polling: (program defaults)
Timeout = 1000
Delay = 200
Time = 0
Period = 0
Command Line = (blank)elee
ParticipantEdit: this issue is intermittent when uploading configurations
elee
ParticipantNeither link worked on Red Hat, installed RapidScada on an Ubuntu machine and connected the administrator from a Windows machine as recommended in another thread.
Thank you
elee
ParticipantSolved…ish
These newer Web Relays can be contacted via modbus or snmp.
elee
ParticipantHello,
I am having the same error, here are the logs:
During the Uploads:
Transfer configuration
Archive size: 157,059 bytesStop the Communicator service
Service control command failed
Stop the Webstation service
Service control command completed successfully
Restart the Server service
Start the Communicator service
Start the Webstation service
Service control command completed successfullyConfiguration uploaded successfully
ScadaComm.log:
2026-06-25 14:58:42 [webserver][root][ACT] Communicator 6.2.0.1 started
2026-06-25 14:58:42 [webserver][root][ACT] Storage FileStorage 6.4.0.0 loaded from file /opt/scada/ScadaComm/FileStorage.dll
2026-06-25 14:58:42 [webserver][root][ACT] Start logic processing
2026-06-25 14:58:42 [webserver][root][ACT] Driver DrvCnlBasic 6.1.0.1 loaded from file /opt/scada/ScadaComm/Drv/DrvCnlBasic.Logic.dll
2026-06-25 14:58:42 [webserver][root][ACT] Driver DrvDsScadaServer 6.0.1.1 loaded from file /opt/scada/ScadaComm/Drv/DrvDsScadaServer.Logic.dll
2026-06-25 14:58:42 [webserver][root][ACT] Driver DrvModbus 6.0.0.5 loaded from file /opt/scada/ScadaComm/Drv/DrvModbus.Logic.dll
2026-06-25 14:58:42 [webserver][root][ACT] Driver DrvSnmp 6.0.0.1 loaded from file /opt/scada/ScadaComm/Drv/DrvSnmp.Logic.dll
2026-06-25 14:58:42 [webserver][root][ACT] Data source ScadaServer initialized successfully
2026-06-25 14:58:42 [webserver][root][ACT] Data source ScadaServer: Receive the configuration database
2026-06-25 14:58:42 [webserver][root][ACT] Data source ScadaServer: The configuration database has been received successfully
2026-06-25 14:58:42 [webserver][root][ACT] Start communication lines
2026-06-25 14:58:42 [webserver][root][ACT] Start reading commands from files
2026-06-25 14:58:42 [webserver][root][ACT] Data source ScadaServer: Connection state is Logged In
2026-06-25 15:00:00 [webserver][root][ACT] Stop communication lines
2026-06-25 15:00:09 [webserver][root][ERR] Data source ScadaServer: Error receiving telecontrol commands:
Incorrect format of data received from the server: unable to read data packet header
2026-06-25 15:00:09 [webserver][root][ACT] Data source ScadaServer: Connection state is Error
Unable to write data to the transport connection: Broken pipe.
Connection refused [::ffff:10.1.10.141]:10000
2026-06-25 15:00:09 [webserver][root][ACT] Unable to stop logic processing for a specified time
2026-06-25 15:00:09 [webserver][root][ACT] Communicator is stopped
2026-06-25 15:00:10 [webserver][root][WARN] Following communication lines are still working: 2
2026-06-25 15:00:52 [webserver][root][ACT] Communicator 6.2.0.1 started
2026-06-25 15:00:52 [webserver][root][ACT] Storage FileStorage 6.4.0.0 loaded from file /opt/scada/ScadaComm/FileStorage.dll
2026-06-25 15:00:52 [webserver][root][ACT] Start logic processing
2026-06-25 15:00:52 [webserver][root][ACT] Driver DrvCnlBasic 6.1.0.1 loaded from file /opt/scada/ScadaComm/Drv/DrvCnlBasic.Logic.dll
2026-06-25 15:00:52 [webserver][root][ACT] Driver DrvDsScadaServer 6.0.1.1 loaded from file /opt/scada/ScadaComm/Drv/DrvDsScadaServer.Logic.dll
2026-06-25 15:00:52 [webserver][root][ACT] Driver DrvModbus 6.0.0.5 loaded from file /opt/scada/ScadaComm/Drv/DrvModbus.Logic.dll
2026-06-25 15:00:52 [webserver][root][ACT] Driver DrvSnmp 6.0.0.1 loaded from file /opt/scada/ScadaComm/Drv/DrvSnmp.Logic.dll
2026-06-25 15:00:52 [webserver][root][ACT] Data source ScadaServer initialized successfully
2026-06-25 15:00:52 [webserver][root][ACT] Data source ScadaServer: Receive the configuration database
2026-06-25 15:00:52 [webserver][root][ACT] Data source ScadaServer: The configuration database has been received successfully
2026-06-25 15:00:52 [webserver][root][ACT] Start communication lines
2026-06-25 15:00:53 [webserver][root][ACT] Start reading commands from files
2026-06-25 15:00:53 [webserver][root][ACT] Data source ScadaServer: Connection state is Logged In
When searching for active ports on the server sudo ss -tulpn
it only shows dotnet as using 10000/8/2
When searching for 10000, sudo ss -tulpn | grep 10000
it shows dotnet but the port is in red…Thank you for your help!
elee
ParticipantAlso,
“The Administrator application should be installed on Windows. It interacts with Rapid SCADA instance, which is installed on Linux, remotely. You should add a new deployment profile in Administrator for remote connection.”
Is there documentation on how to set this up? I do not mind having the administrator application on a windows machine. My RapidScada will be hosted on a Linux VM and ideally would not need much changes when fully stablished.
elee
ParticipantMikhail,
When attempting command: wine [file path]/ScadaAdmin.exe
the warning is that the program encountered a serious problem and needs to close.
(downloaded 2026 zip from drive location)elee
Participantsolved: called ‘extra scheme components’ in store
elee
ParticipantHow do i get extended mimic components?
elee
ParticipantThank you Manjey73, I will try this mimic option.
For Dashboards, I have successfully linked to one url in the dashboard, how can i link to another that requires a login?
elee
ParticipantSolved, i needed to change the view type in the views table.
elee
ParticipantI am trying to embed a webpage from another device in one of my mimics, is the dashboard plugin the only way to do so?
elee
ParticipantThank you for the reply. Which settings? These are the webstation logs from yesterday.
2026-06-16 06:31:59 [ENG-ISP][ENG-ISP$][ACT] Webstation 6.2.3.1 started
2026-06-16 06:31:59 [ENG-ISP][ENG-ISP$][ACT] Storage FileStorage 6.4.0.0 loaded from file C:\Program Files\SCADA\ScadaWeb\FileStorage.dll
2026-06-16 06:32:00 [ENG-ISP][ENG-ISP$][ACT] Plugin PlgChart 6.1.0.1 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgChart.dll
2026-06-16 06:32:00 [ENG-ISP][ENG-ISP$][ACT] Plugin PlgDashboard 6.1.1.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgDashboard.dll
2026-06-16 06:32:00 [ENG-ISP][ENG-ISP$][ACT] Plugin PlgMain 6.1.2.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgMain.dll
2026-06-16 06:32:00 [ENG-ISP][ENG-ISP$][ACT] Plugin PlgMimic 6.0.2.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgMimic.dll
2026-06-16 06:32:00 [ENG-ISP][ENG-ISP$][ACT] Plugin PlgMimicEditor 6.0.2.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgMimicEditor.dll
2026-06-16 06:32:00 [ENG-ISP][ENG-ISP$][ACT] Plugin PlgMimBasicComp 6.0.1.1 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgMimBasicComp.dll
2026-06-16 06:32:00 [ENG-ISP][ENG-ISP$][ACT] Plugin PlgMimShapesJP 6.0.1.1 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgMimShapesJP.dll
2026-06-16 06:32:00 [ENG-ISP][ENG-ISP$][ACT] Plugin PlgScheme 6.1.1.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgScheme.dll
2026-06-16 06:32:00 [ENG-ISP][ENG-ISP$][ACT] Plugin PlgSchBasicComp 6.1.0.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgSchBasicComp.dll
2026-06-16 06:32:00 [ENG-ISP][ENG-ISP$][ACT] Plugin PlgStore 6.1.0.1 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgStore.dll
2026-06-16 06:32:00 [ENG-ISP][ENG-ISP$][ACT] Plugin PlgWebPage 6.1.1.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgWebPage.dll
2026-06-16 06:32:00 [ENG-ISP][ENG-ISP$][ACT] Check PlgDashboard registration: Registration key is valid. Expiration date is 16/06/2026.
Computer code: =B075CFF7CAD04C9E-D8A2F6A29D73A21B-E4F2CA1BE47B327D-FAAC70512454CF2D-3B3A81407F9794BA-D277060ABBCA6241-45C1C53550E1B386-87A5829DEECB5C8A=
Registration key: 67432C703CE09DDD-771B85C06202B4B3-44A332105653CD59
2026-06-16 06:32:00 [ENG-ISP][ENG-ISP$][ACT] Plugin PlgMimic: Add components from the PlgMimBasicComp plugin
2026-06-16 06:32:00 [ENG-ISP][ENG-ISP$][ACT] Plugin PlgMimic: Add components from the PlgMimShapesJP plugin
2026-06-16 06:32:00 [ENG-ISP][ENG-ISP$][ACT] Plugin PlgScheme: Retrieve scheme components from the installed plugins
2026-06-16 06:32:00 [ENG-ISP][ENG-ISP$][ACT] Plugin PlgScheme: Added components from the PlgSchBasicComp plugin
2026-06-16 06:32:00 [ENG-ISP][ENG-ISP$][ACT] Receive the configuration database
2026-06-16 06:32:02 [ENG-ISP][ENG-ISP$][ACT] The configuration database has been received successfully
2026-06-16 06:32:02 [ENG-ISP][ENG-ISP$][INF] The application is ready for operating
2026-06-16 06:33:02 [ENG-ISP][ENG-ISP$][ACT] User admin is logged in, role 1, IP ::1 -
