WayneS
Viewing 15 posts - 1 through 15 (of 34 total)
  • in reply to: Default properties for newly created channels #18139
    WayneS
    Greetings from New Zealand,
    I have found the easiest way to do this is to use the Tools/project tools/export table to export your channels to a spreadsheet (.csv). You have then copy the channel(s), change the channel numbers. Once finished save the spreadsheet as a .csv then use the import table to add the new channels. I did this for three large identical devices – make the first one with channel numbers 1000-1999, then copy and nake second one 2000-2999, thord one 3000-3999.
    regards Wayne
    in reply to: Currency Format #17922
    WayneS
    Hi Mikhail,
    Thank you that worked perfectly.
    Rapid SCADA is working really well.
    regards
    Wayne
    in reply to: MQTT – period must be less than 65 seconds #17918
    WayneS
    Hi Mikhail,
    Thanks, that’s working well now.
    regards
    Wayne
    in reply to: MQTT – period must be less than 65 seconds #17908
    WayneS
    Hi Mikhail,
    I downloaded the update and copied the files into my “program files/SCADA” directory. I checked that the files had been replaced. I then uploaded the project and changed the publishing times. At 1 minute, it worked well. At 2 minutes, every second one failed.
    regards
    Wayne
    in reply to: MQTT – period must be less than 65 seconds #17893
    WayneS
    Hello Mikhail.
    Screenshoots:
    https://ibb.co/qMbS10D1
    https://ibb.co/BH7wSg53
    https://ibb.co/M5KKjwwv
    One shows the driver settings, one is the log just after restarting while the last is the log sometime after starting showing errors.
    regards
    Wayne
    in reply to: Setting up postgreSQL #17803
    WayneS
    Thanks Mikhail,
    The Archive table in the configuration database was exactly what I was missing – have corrected this and away it went. Great product.
    regards Wayne
    in reply to: Setting up postgreSQL #17800
    WayneS
    The standard archives are working well and saving data to postgresql, however I can’t make the custom archive work and indeed if I change the name of the standard archives (e.g. hour/hourcopy to 30min/30mincopy) they stop working.
    I’m using the hour archive on a 30 minute period and it would be nice to make the name more accurate.
    Is it possible to make the custom archive work or to change the name of the standard archives?
    regards
    Wayne
    in reply to: Setting up postgreSQL #17768
    WayneS
    Hi
    And if you want to change the password in ScadaInstanceConfig.xml, how do you encode it? e.g. to user koolbeer123 as a password what do you put in the ScadaInstanceConfig.xml?
    regards
    Wayne
    in reply to: Setting up postgreSQL #17760
    WayneS
    Hi Mikhail
    I found the issue. Regardless of what user/password you setup in the Server/module ModArcPostgreSQL Connection settings, rapid_scada uses postgres/postgres. If you change the database password to postgres it works.
    regards
    Wayne
    in reply to: Setting up postgreSQL #17758
    WayneS
    Thanks Mikhail,
    The settings were all OK for password auth. I tried changing to MD5 and trust, but made no difference. I also made a new user/password. I can connect to the database OK with either the postgres user or my new user using both pgadmin4 and dbvisualiser.
    Not sure where to go next?
    regards
    in reply to: Setting up postgreSQL #17754
    WayneS
    OK tried that and discovered that autheication isn’t working. 100% certain login name (postgres) and password are correct. Any suggestions
    From log file:
    2026-03-18 15:33:21 [RANUI-SOLAR][RANUI-SOLAR$][ERR] Error calling the MakeReady method of the HourCopy archive:
    Npgsql.PostgresException (0x80004005): 28P01: password authentication failed for user “postgres”
    at Npgsql.Internal.NpgsqlConnector.ReadMessageLong(Boolean async, DataRowLoadingMode dataRowLoadingMode, Boolean readingNotifications, Boolean isReadingPrependedMessage)
    at System.Runtime.CompilerServices.PoolingAsyncValueTaskMethodBuilder1.StateMachineBox1.System.Threading.Tasks.Sources.IValueTaskSource<TResult>.GetResult(Int16 token)
    at Npgsql.Internal.NpgsqlConnector.AuthenticateSASL(List`1 mechanisms, String username, Boolean async, CancellationToken cancellationToken)
    at Npgsql.Internal.NpgsqlConnector.Authenticate(String username, NpgsqlTimeout timeout, Boolean async, CancellationToken cancellationToken)
    at Npgsql.Internal.NpgsqlConnector.<Open>g__OpenCore|213_1(NpgsqlConnector conn, SslMode sslMode, NpgsqlTimeout timeout, Boolean async, CancellationToken cancellationToken, Boolean isFirstAttempt)
    at Npgsql.Internal.NpgsqlConnector.Open(NpgsqlTimeout timeout, Boolean async, CancellationToken cancellationToken)
    at Npgsql.PoolingDataSource.OpenNewConnector(NpgsqlConnection conn, NpgsqlTimeout timeout, Boolean async, CancellationToken cancellationToken)
    at Npgsql.PoolingDataSource.<Get>g__RentAsync|33_0(NpgsqlConnection conn, NpgsqlTimeout timeout, Boolean async, CancellationToken cancellationToken)
    at Npgsql.NpgsqlConnection.<Open>g__OpenAsync|42_0(Boolean async, CancellationToken cancellationToken)
    at Npgsql.NpgsqlConnection.Open()
    at Scada.Server.Modules.ModArcPostgreSql.Logic.PostgreHAL.CreateDbEntities()
    at Scada.Server.Modules.ModArcPostgreSql.Logic.PostgreHAL.MakeReady()
    at Scada.Server.Engine.ArchiveHolder.MakeReady()
    Exception data:
    Severity: FATAL
    SqlState: 28P01
    MessageText: password authentication failed for user “postgres”
    File: auth.c
    Line: 324
    Routine: auth_failed
    in reply to: Setting up postgreSQL #17751
    WayneS
    Hi Mikhail,
    I’m halfway through comissioning a solar farm, which is using rapid_scada.
    Screenshots are here:postgre screenshots
    Queries use Query Text
    regards
    wayne
    in reply to: Setting up postgreSQL #17746
    WayneS
    I found the initial issue – I had the user name wrong ‘postgres’ not ‘postgre’. So now I have a connection but still don’t have any data being saved in the database. I also don’t have log files associated with the modules i.e. ModDbExport.log etc. Perhaps something is wrong with my installation?
    I have followed the instructions in the documentation and created the query as per the link.
    The more I use Rapid SCADA the more I think this is a really great product 🙂
    regards
    in reply to: Working on a project pulled from another PC #17256
    WayneS
    Hi there
    I use onedrive, with the ScadaProjects directory in the documents folder, i.e. the same place on any PC that I’m logged into onedrive on. That way I don’t copy it, just open it on the other PC.
    regards
    in reply to: Some channels muted in Notifications #17233
    WayneS
    Hi Mikhail,
    For unknown reasons some channels seem not to generate events. The only way I found to fix this was to delete the channel, then recreate it with exactly the same definition and this allowed the limits to generate events. Note varying channel past the limit changed its colour, but didn’t generate and event.
    regards
    Wayne
