HourStarted() doesn’t evaluate to true
Forum Home › Forums › Understanding the Software › Formulas › HourStarted() doesn’t evaluate to true
  • #16659
    WayneS
    When I use the formula below, it constantly increments and does not reset to 0. It appears to me the HourStarted() doesn’t ever give a true.
    EveryMin(() => HourStarted() ? 0 : Val() + 1)
    regards
    #16662
    HourStarted() is running with a delay. The revision of the formulas has apparently not yet been included in the release.
    HourStarted
    Use a translator if you need to understand.
    #16663
    The reason turned out to be that the HourStarted formula was triggered after 30 seconds, as the hour arrived, and EveryMin was triggered at 0 seconds. The delay in the HourStarted formula is useful in some cases.
    You can update the Scripts table in the Calendar entry to make it work.:
    These changes will be included in the project template in the next release.
    • This reply was modified 1 year, 4 months ago by manjey73.
    #16665
    WayneS
    Thanks,
    That makes sense, I did wonder why it was set at >=30 seconds – will fix that.
    regards
    Wayne
    #16666
    As the author noted, the delay in hourly formulas can be useful, but here it is necessary to combine the minute with the hour, and this usefulness went sideways 🙂
