Viewing 15 posts - 1,141 through 1,155 (of 6,389 total)
  • in reply to: More detailed archive classification #14727
    Currently, this feature is not supported. I hope we will implement it in the future.
    in reply to: Dropdown menu #14725
    If you are asking about adding a menu on a mimic diagram, currently this is not supported. You could add buttons, or display another view in a modal dialog by clicking a button.
    in reply to: Installation Failure IIS 7 #14724
    Check this link.
    in reply to: DB export #14720
    The screenshot is correct. You can set device and object fields to empty. Channel number is enough.
    Press F12 in browser and check if there are any errors in console.
    in reply to: DB export #14714
    Don’t forget to check variables available in a SQL request.
    in reply to: DB export #14713
    If I understand the question correctly, you need to execute a SQL query on a command. First, try sending a command manually by a user. Note that SetData() function does not send a command. To send commands according to conditions, use Automatic Control Module.
    in reply to: TCP/IP Problem #14712
    ByDriver means that a driver parses an incoming request to decide what device the request belongs to. It is usually used in slave mode when we cannot identify device by IP or hello packet.
    in reply to: TCP/IP Problem #14711
    The existing configurations belong to project owners, so can’t be shared. Provide screenshots of your settings to check.
    Note that after connection a modem should send a “hello packet” to identify a device. If it’s not supported by the modem, you need to use different TCP port for each device.
    Configure a Modbus Slave device. Then you will find the code in ScadaComm.log
    in reply to: Logging Data per second #14701
    Archive kind should be Historical.
    The Is Default checkbox should be unset.
    in reply to: Any questions about Rapid SCADA and Raspberry Pi #14700
    The above link is not public.
    The issue does not seem Raspberry specific. I suggest to find a proper topic related to MQTT communications for continue.
    in reply to: Error: Garbage collecctor… #14698
    Mono framework can have memory leaks. .NET 8 is much better.
    > When I upgrade to version 6, do I need new license keys?
    First, try the existing keys. We can upgrade the keys for the same machine for free if needed.
    in reply to: Historical data report achieve copy #14697
    Thank you for the info about the result.
    in reply to: TCP/IP Problem #14696
    If a communication line is working as TCP server, make sure that incoming connections are enabled in the firewall settings.
