Viewing 15 posts - 1,036 through 1,050 (of 6,388 total)
  • Mikhail
    Using Rapid SCADA you can collect data from various devices, store data into a database, and display to an operator. I suggest to start from watching video lessons and reading docs (link).
    in reply to: Sequential Running of Outputs #15096
    1. When creating a time trigger, you can enter time with seconds. If it’s doesn’t work for you, please provide a screenshot.
    2. If it should repeat not too fast, you can enter many times of day in the trigger options. Alternatively, you should create a channel that changes from 0 to 1 every X minutes, and create a data trigger that reacts on the channel.
    in reply to: Sequential Running of Outputs #15092
    Try creating a time trigger in Automatic Control Module. Use the Delay parameter of commands to send them as a sequence.
    in reply to: First time update of Digital Output status #15091
    Please provide links to screenshots.
    in reply to: OPC DA no values received #15086
    > Is there any way one can support you?
    Purchase of any additional modules is appreciated.
    in reply to: Integrating 3 colour LED Module #15084
    Automatic Control Module is useful when you need to send commands according to conditions.
    First, connect the equipment and try sending commands manually. After you make it work, use ACM.
    in reply to: Rest API integration #15082
    In Visual Studio 2022 Community when create a new project.
    in reply to: OPC DA no values received #15081
    You should try the setup the ScadaComm6 service to work as the OPCSrv user. See this.
    It’s enough to restart Communicator that works as a service or application.
    in reply to: Change default port number 10008 #15074
    If you didn’t change the port during installation, use the method described above.
    in reply to: Channel Read Bits #15071
    I could not understand how to try the B Format as there is no option for B.
    In the Formats table add a new format. I’m not sure that B will work, however, it worth to try.
    in reply to: Channel Read Bits #15070
    I didn’t know there was a binary display format
    It was added in .NET8. I’ve never tried it before.
    Chart Pro falls on the string variable – a white screen
    It cannot display graph of a string.
    in reply to: OPC DA no values received #15069
    2024-07-29 13:30:51 [OPC-WINCC][OPC-WINCC$][ACT] Data source ScadaServer: Receive the configuration database
    2024-07-29 13:30:53 [OPC-WINCC][OPCSrv][ACT] Data source ScadaServer: Connection state is Logged In
    Looks like the ScadaComm6 service is not stopped. Users OPC-WINCC$ and OPCSrv are mixed in the log file.
    in reply to: V6 Captcha on the login screen #15061
    You need to create your own module that performs auth. The links below can help.
    Link 1
    Link 2
    The above post is not related to the topic. Please search for existing topics about Modbus. Probably, it’s already solved.
    in reply to: Channel Read Bits #15057
    Also hexadecimal format would be useful.
