Viewing 15 posts - 676 through 690 (of 6,387 total)
  • in reply to: Not getting to view as a web page #16306
    Let’s discuss another topic in the appropriate forum thread. Use the search, maybe the answer is already there.
    in reply to: Not getting to view as a web page #16303
    “An error occurred while processing your request.” is a sub message.
    If you see it, check the details in ScadaWeb.log
    When it happens?
    in reply to: Buid Rapid SCADA 6 on Visual Studio Code #16302
    There is no plans to adopt SchemeEditor for Wine, because I hope, the new MimicEditor will be released. But I don’t know when it happens. The work in progress.
    Can you run ScadaAdmin on arm64? If so, how to achieve that?
    in reply to: Auto Control Module Bug #16301
    Please provide screenshots of the module settings and log.
    What are the versions of the Server service and the module?
    in reply to: New release Rapid SCADA 6.4.x #16294
    Rapid SCADA 6.4.1 has been released.
    – Improved API of plugins and extensions (backward compatibility is supported)
    – Fixed errors in MQTT and DB Import drivers
    – The Server service writes initial command values ​​to events before calculating by formula
    – PostgreSQL historical archive supports in-memory caching
    The projects are fully compatible with the previous release.
    in reply to: Not getting to view as a web page #16292
    You can see that the Channel column is empty. It should be filled by the channel numbers. I suggest to delete the channels related to the device (in the Channels table) and create channels again using the wizard.
    • This reply was modified 1 year, 6 months ago by Mikhail.
    in reply to: Not getting to view as a web page #16290
    After you successfully displayed a table view, you should check a data page in Communicator to make sure that you receive valid data from devices.
    in reply to: Not getting to view as a web page #16285
    Please check ScadaWeb.log for the error details.
    in reply to: schemeeditor doesn’t launch at all – windows11 #16284
    Wow! Windows is unpredictable sometimes.
    in reply to: Tagging Asset using SCADA #16278
    Could you clarify the question?
    in reply to: Not getting to view as a web page #16277
    In ScadaServer.log, there is no connection made by the ScadaWeb user. It looks like the web application tries to connect to another TCP port. Open the connection options of the Webstation app using the Administrator app and check that the port 10000 is set there.
    in reply to: schemeeditor doesn’t launch at all – windows11 #16270
    Make sure that the latest updates are installed on your Windows 11.
    in reply to: Not getting to view as a web page #16269
    Using the TcpView utility make sure that TCP port 10000 is not being used by any other application except the ScadaServer service.
    in reply to: Not getting to view as a web page #16268
    Please also provide ScadaServer.log
    in reply to: schemeeditor doesn’t launch at all – windows11 #16267
    Thank you for the info.
    Scada.Scheme.Editor.AppData.StartWcfService(System.String ByRef)
    The above line means that the error occurred when starting a WCF service.
    This discussion is related to the issue, but it does not contain a solution.
    We are planning to get rid of WCF in Scheme Editor. Until then, I suggest using a virtual machine to create schemes.
