Viewing 15 posts - 6,001 through 6,015 (of 6,387 total)
  • in reply to: Firefox left w/ graphs open overtakes RAM #1030
    Is the only chart web page is open? I mean do you close the main web form with scheme or table view?
    When you test the same with IE and Chrome please write about the result.
    in reply to: Communicator using 100% CPU #1029
    Please, post a part of the communication line log when this situation occurs.
    If you stop communication line (from context menu), CPU load become low?
    in reply to: Communicator using 100% CPU #1027
    communicator not taking over the CPU.
    Sorry, I didn’t catch what the error is?
    in reply to: Excel Exporting #1024
    Please download Rapid SCADA again and update SCADA-Web application. Is it possible to just overwrite the files from ScadaWeb.zip
    in reply to: I cant see Scada Comunicator window #1023
    I observed this also, is there a reason it starts up minimised to the tray?
    Let me think about it 🙂
    in reply to: I cant see Scada Comunicator window #1022
    Are the requested files here C:\SCADA\ScadaWeb\config\ ?
    Do use use default installation directory C:\SCADA ?
    in reply to: Scheme Symbols/IMG #1018
    The beta version of the new schemes will be released in the summer 2016. In the first time it will support the existing format of schemes. SVG will be supported a bit later. Bootstrap is used. New components such as gauges will be added in the same time as SVG.
    Thank you for your patience 🙂
    In Chrome:
    1
    in reply to: I cant see Scada Comunicator window #1017
    It is collapsed to a tray icon after start. Look for it in the right botton corner of your desktop.
    in reply to: Excel Exporting #1014
    The reports are in SpreadsheedML format. It is XML that can be opened by Microsoft Excel and by Libre Office.
    in reply to: Excel Exporting #1013
    It’s great that you ask. The report allows to export minute data to excel is ready. It will be included in the installation package within a few days. It can be executed from the reports page and it is integrated with Chart Pro component.
    For now you can choose begin and end dates of a period of a report. In case of requirements to choose a time, some development is needed.
    in reply to: Scheme Symbols/IMG #1010
    Is there a free HMI/Scada free IMG repository available?
    Not yet. I usually look for images in Google Images
    How does Dinamic IMG works and what is the format for it?
    It shows an image depending on Input channel value and its Conditions property.
    You can use PNG and JPG image formats.
    How can i make new IMGs? Is it possible to use Inkscape-Sage?
    Any image editor. I use Microsoft Visio. Inkscape is good, but you should convert images to PNG or JPG.
    For example, is it possible to make a gauge that the pointer changes according to the input of a tag?
    For now you should create a set of images with different levels and use Dynamic picture component. In the future such components will be developed.
    in reply to: Calculated Real working unreliable #1007
    After getting every block of data from Communicator, the calculated channels are updated. Could you describe the issue in details?
    in reply to: Web Page don't open in other computers. #1006
    First of all, make sure that the web site on 192.168.0.12 is accessible: try to open http://192.168.0.12
    If not, may be the cause is firewall.
    in reply to: Modbus Byte Order #1003
    Thank you very much for the detailed research.
    The fix is ready. Please send a letter to info -a- rapidscada.org, I will send you the fix to try.
    in reply to: Graphs not updated (on a win2003 server) #997
    BTW… schemes are working too! good job!
    magic 🙂
