In new mimic diagrams, you can also add a component and set Visible to false. But it is not convenient for many channels.
What is your situation? Why do you need to add more channels to a view?
Please provide the corresponding screenshots.
MikhailModeratorPlease let me know about the result.
In ScadaServer.log
2026-08-05 18:59:22 [ENGINEERING][ENGINEERING$][ACT] Command to channel 104 from user with ID 2 2026-08-05 18:59:22 [ENGINEERING][ENGINEERING$][ACT] Command is queued to be sent to clients
That’s good.
I guess that Communicator does not receive commands, because both the ScadaGenerator app and the ScadaComm service are logged-in as the ScadaComm user. There is a protection to avoid infinite command loop. Try using the ScadaWeb user in ScadaGenerator.
MikhailModeratorI thought about a script, which checks the current local time and stores day and month starts values in separate channels.
This is possible.
For the second one (which grows continuously) I need a daily and monthly value.
Try ModDiffCalculator for that channels. Also Elastic Report Plugin can calculate the differences.
For now ibb.co is down. Could you upload the screenshots to another hosting?
If you use Time/Period, Delay is not needed.
Delay is useful to slow down polling if Time and Period = 0.
MikhailModeratorEach case requires each own formula. There is not enough information to make a recommendation. If data has been collected, related screenshots can help.
You should play with Time/Period parameters. Set them to 00:00:05/00:00:10, for example, and check communication line log.
The Delay parameter specifies a delay after each request.-
This reply was modified 3 months, 3 weeks ago by
MikhailModeratorPublished at https://rapidscada.net/store/Module/en/PlgMimControlsJP
MikhailModeratorPublished at https://rapidscada.net/store/Module/en/PlgTrendJP
MikhailModeratorPublished at https://rapidscada.net/store/Module/en/PlgMimTankJP
MikhailModeratorPlease describe and provide examples of the channels that act as sources.
MikhailModeratorYou should check the historical archive options.
I suppose, it is possible to disable auto recoding data, so it will not be overwritten. And there is an option to pull timestamps to the period.
Of course, for production, you should update password for the DB, and change it in ScadaInstanceConfig.xml. Note that it is encrypted there. -
