MikhailModeratorI can try to fix it using remote connection if you OK with the commercial service. For pricing, please send a request to this email.
You should provide a part of communication line log where we can see the raw data packages from the device. And provide screenshot of the Modbus template.
MikhailModeratorAdd a command to your Modbus template, restart Communicator and try the command using the UI of Communicator. When you sure it works, you can add output channel in Administrator.
This reply was modified 8 years, 5 months ago by
You create an interesting system.
What Modbus registers do you need to set by a command?
You could try to configure the command as you expect, and if it doesn’t work, post screenshot links of the settings to discuss them.
If you can’t fix it by yourself, be free to ask.
MikhailModeratorNo programmatic limits. You should check performance of your real system.
Despite of Communicator settings, all input channels have double data type. You should search for the cause in Communicator.
MikhailModeratorUseful, thank you 🙂
MikhailModeratorHi José,
I recommend Notepad++ for editing XML. WordPad may corrupt them. You can download Notepad++ from https://notepad-plus-plus.org/
You should check C:\SCADA\ScadaSchemeEditor\Log\ScadaSchemeEditor.log for error details.
Before you send the files to me, try to check them by yourself. I can help you to understand meanings of error messages.
That would be great!
I fixed the error related to Communicator. Download Language Pack again, please.Talking about Scheme Editor, the file ScadaSchemeEditor\Lang\ScadaSchemeEditor.es-LA.xml is outdated. You have 2 options:
1. The best is creating a new translation for Scheme Editor.
Copy ScadaSchemeEditor.en-GB.xml to ScadaSchemeEditor.es-LA.xml. Then open it and translate the phrases. When it is tested, you could send me the file to include in the pack.2. Delete ScadaSchemeEditor.es-LA.xml and use the editor in English.
It means that IIS doesn’t work. You should check the installed components. Also check the port 80, may be it is used by another application.
What is displayed by http://localhost/ ? -
