Forum Home › Forums › Uncategorized Issues › AutoControll load problem
- This topic has 10 replies, 3 voices, and was last updated 8 years, 9 months ago by
March 7, 2016 at 12:04 pm #875
scodina
ParticipantI download Automatic Control Module, put it on the right folder, but when I “Add module” from scada-server this is the error:
Error loading module:
È stato effettuato un tentativo di caricamento di un assembly da un percorso di rete, il che avrebbe causato la creazione mediante sandbox dell’assembly nelle versioni precedenti di .NET Framework. In questa versione di .NET Framework i criteri di sicurezza dall’accesso di codice non sono abilitati per impostazione predefinita, pertanto questo tipo di caricamento può risultare pericoloso. Se il caricamento non è effettuato per creare l’assembly mediante sandbox, abilitare l’opzione loadFromRemoteSources. Per ulteriori informazioni, vedere http://go.microsoft.com/fwlink/?LinkId=155569.March 7, 2016 at 8:20 pm #879
MikhailModeratorRight click DLL and click Unblock button. The example
January 1, 2018 at 5:51 pm #2995LPG57
ParticipantMikhail,
I’m having the same trouble as mentioned above. I tried with unblocking the dll, but it didn’t help.January 1, 2018 at 7:49 pm #2997
MikhailModeratorDo you mean that error is the same after unblock?
Please provide a screenshot.January 6, 2018 at 11:07 am #3023January 6, 2018 at 5:25 pm #3024January 6, 2018 at 6:20 pm #3025LPG57
ParticipantYes, the solution in link 1 worked, copied the file to the desktop, unblocked it and copied it back.
BTW, how is the Computer code generated (for purchasing the license)?
January 6, 2018 at 6:51 pm #3026LPG57
ParticipantA new problem: when trying to save the commands, I get the following error:
http://www.granberg.tv/Capture3.PNGJanuary 7, 2018 at 6:56 am #3028
MikhailModeratorIt’s easy to solve:
Download the current installation package from the website. Find ScadaServer.zip and copy ScadaData.dll to C:\SCADA\ScadaServer
There was a bug and now it is fixed.how is the Computer code generated (for purchasing the license)?
You can see it when open properties of the module on the Registration tab.
January 7, 2018 at 2:33 pm #3031LPG57
ParticipantThis issue is solved after your instructions above. Automatic Command tested and working!
Thank You!
January 8, 2018 at 2:15 pm #3035
MikhailModeratorNice 🙂
