Viewing 15 posts - 4,921 through 4,935 (of 6,391 total)
  • in reply to: New Agent Application #3742
    You should allow incoming connections for the TCP port 10002 in the settings of Windows firewall to enable access to Agent.
    in reply to: PID Control #3741
    The existing Link component allows to redirect to another scheme where you can put needed components. It is planned to add a popup dialogs feature for links in this year.
    in reply to: Using the new basic scheme components #3740
    You can do a trick:
    1. Create a folder C:\SCADA\ScadaWeb\plugins\SchBasicComp\lang\
    2. Copy the PlgSchBasicComp.en-GB.xml into this folder.
    The fix of this bug will be included in the next version of Rapid SCADA.
    in reply to: Using the new basic scheme components #3738
    The web app must be in C:\SCADA\ScadaWeb because of this bug. Is it?
    in reply to: New Agent Application #3735
    Control RAM on Linux. Agent uses WCF technology that has a memory leak bug on Mono .NET Framework.
    in reply to: Using the new basic scheme components #3731
    I suppose, the cause is your localization. I reproduced the bug. What culture did you set for Rapid SCADA?
    in reply to: Using the new basic scheme components #3730
    Also try unblocking the DLLs in C:\SCADA\ScadaWeb\bin
    See this.
    in reply to: Random Number Generator #3729
    Yes, you right.
    in reply to: PID Control #3728
    First, it’s needed to implement math algorithm. It is better to develop a module for the Server app.
    Then, configure user interface. How do think, to display it?
    Do you mean PID like this?
    in reply to: Using the new basic scheme components #3727
    Anyway, this is strange.
    What version of Windows do you use?
    Is it possible to try Webstation and Scheme Editor on another computer just for test?
    in reply to: Using the new basic scheme components #3725
    Try updating ScadaSchemeCommon.dll.
    Copy it in C:\SCADA\ScadaWeb\bin
    Please tell about the result.
    • This reply was modified 8 years, 5 months ago by Mikhail.
    in reply to: Remote commumicator #3718
    Thank you 🙂
    in reply to: Random Number Generator #3717
    Yes. You should use Random class.
    In the Formulas table add a variable:
    Random rand = new Random();
    Then use it in an input channel, for example:
    rand.NextDouble()
    in reply to: Alien LiveChart or Gage #3713
    Yes, you have to create cnlFilter object before executing getCurCnlDataExt. Could you create a new topic for your issue, because this is “New ideas” subforum?
    Example is here.
    in reply to: Using the new basic scheme components #3712
    You need the Webstation app installed, because the components are the part of the web application.
    Also check log of Scheme Editor in C:\SCADA\ScadaSchemeEditor\Log
