Viewing 15 posts - 4,876 through 4,890 (of 6,391 total)
  • in reply to: Scada Namespace file #3906
    You should build the solutions that are included in Rapid SCADA in the proper order. See this file https://github.com/RapidScada/scada/blob/master/HowToBuild.txt
    If it doesn’t help, provide more info about the error. Screenshots preferable
    in reply to: HTTPS on Linux #3901
    Try these config files. They work for enabling HTTPS on Windows, you can help to test them on Linux.
    If it doesn’t help, you can try deleting the folder ScadaWeb/plugins/Scheme for testing purposes. This is the Schemes plugin that caused the above error.
    in reply to: Elastic Report Flexibility #3900
    Could you provide an example of a required report?
    in reply to: How to complete customization a web UI? #3899
    For animated elements you need to create animated GIFs by any external editor. For animated levels, probably, it’s needed to develop a special scheme component.
    If animated elements are not critical, creation of similar UI is easy.
    in reply to: General Configuration Sequence #3894
    So, today I clicked on Communicator in my Windows 8.1 Apps list and got a message that it was already running. There is no evidence of that. So far, I am stymied.
    Cool! Now you can close application if you need, and you will not get a message that the app is already running.
    in reply to: General Configuration Sequence #3888
    You should click the small arrow to the left of the flag.
    Then I expect you find SCADA-Server and Communicator icons. When you click an icon, an appropriate application is shown.
    in reply to: Tool for User Administration #3880
    Good question. Nope. To make this feature possible, SCADA-Server needs to support command of updating users (rights, etc.) without restart.
    I hope in this year we develop a mechanism that allow to workaround this issue and use external module to login and access management.
    In the future it should be possible out of the box.
    in reply to: Send Setpoint value (float number) #3879
    The command has been sent successfully
    This message means sending command from the shell to the service.
    in reply to: Send Setpoint value (float number) #3878
    In the log file there is no trace from the command
    You need to find info in a communication line log. The name of the file is C:\SCADA\ScadaComm\Log\lineXXX.log
    I think this will clarify the cause.
    in reply to: Update problems #3877
    The problem of the new installation was fixed with pressing Ctrl+F5 in the Browser.
    Definitely, this was a cause. When the scripts of the web application change, it is required to fully update web pages or clear browser cache.
    in reply to: General Configuration Sequence #3876
    Can you make a screenshot of the tray icon area?
    in reply to: OPC Write value issue – Matrikon Simulation #3863
    Great ))
    in reply to: General Configuration Sequence #3862
    Use any image hosting for upload screenshots. For example https://imgur.com/
    in reply to: General Configuration Sequence #3856
    Please provide the screenshots.
    in reply to: OPC Write value issue – Matrikon Simulation #3853
    The command was sent successfully
    This means just sending to the Communicator service.
    See what is written in the communication line log in Communicator at the moment right after you send a command. You can find logs in C:\SCADA\ScadaComm\Log
