Scada Namespace file
Forum Home › Forums › Understanding the Software › Scada Namespace file
  • #3905
    Hello Mikhail,
    First of all thanks for the very good app as open source project.
    I have the source code from github
    But how should i proceed with the source code in Visual Studio
    it says Scada namespace file is missing ,
    which is to solution need to build to have some changes at UI.
    or do you have any documentation. Please update.
    #3906
    You should build the solutions that are included in Rapid SCADA in the proper order. See this file https://github.com/RapidScada/scada/blob/master/HowToBuild.txt
    If it doesn’t help, provide more info about the error. Screenshots preferable
    #3912
    error finding a reference
    Hi Mikhail ,
    I tried building Log solution build was successful but i am stuck at Report solution it says some reference is missing , please help,
    image is attached.
    image kink: image
    Thanks in advance.
    #3919
    Hi ,
    Now i am using visual studio community 2015
    i am opening as website if go to build it shows some error screenshot attached , please help in building this project.screenshot
    screenshot
    #3920
    —— Build started: Project: Scada, Configuration: Debug Any CPU ——
    Validating Web Site
    Building directory ‘/Log/Log/Properties/’.
    Building directory ‘/Log/Log/’.
    Building directory ‘/Report/RepBuilder/’.
    Building directory ‘/Report/RepExec/’.
    Building directory ‘/ScadaAdmin/ScadaAdmin/AppCode/’.
    Building directory ‘/ScadaAdmin/ScadaAdmin/Connected Services/AgentSvcRef/’.
    Building directory ‘/ScadaAdmin/ScadaAdmin/Properties/’.
    Building directory ‘/ScadaAdmin/ScadaAdmin/Remote/’.
    Building directory ‘/ScadaAdmin/ScadaAdmin/’.
    Building directory ‘/ScadaAgent/ScadaAgentCore/’.
    Building directory ‘/ScadaAgent/ScadaAgentMono/Properties/’.
    Building directory ‘/ScadaAgent/ScadaAgentMono/’.
    Building directory ‘/ScadaAgent/ScadaAgentNet/Properties/’.
    Building directory ‘/ScadaAgent/ScadaAgentNet/’.
    Building directory ‘/ScadaAgent/ScadaAgentSvc/Properties/’.
    Building directory ‘/ScadaAgent/ScadaAgentSvc/’.
    Building directory ‘/ScadaAgent/ScadaAgentTest/Connected Services/AgentSvcRef/’.
    Building directory ‘/ScadaAgent/ScadaAgentTest/Properties/’.
    Building directory ‘/ScadaAgent/ScadaAgentTest/’.
    Building directory ‘/ScadaComm/OpenKPs/AddressBook/Properties/’.
    Building directory ‘/ScadaComm/OpenKPs/AddressBook/’.
    Building directory ‘/ScadaComm/OpenKPs/KpEmail/Properties/’.
    Building directory ‘/ScadaComm/OpenKPs/KpEmail/’.
    Building directory ‘/ScadaComm/OpenKPs/KpHttpNotif/HttpNotif/UI/’.
    Building directory ‘/ScadaComm/OpenKPs/KpHttpNotif/HttpNotif/’.
    Building directory ‘/ScadaComm/OpenKPs/KpHttpNotif/Properties/’.
    Building directory ‘/ScadaComm/OpenKPs/KpHttpNotif/’.
    Building directory ‘/ScadaComm/OpenKPs/KpModbus/Modbus/Protocol/’.
    Building directory ‘/ScadaComm/OpenKPs/KpModbus/Modbus/UI/’.
    Building directory ‘/ScadaComm/OpenKPs/KpModbus/Properties/’.
    Building directory ‘/ScadaComm/OpenKPs/KpModbus/’.
    Building directory ‘/ScadaComm/OpenKPs/KpSms/Properties/’.
    Building directory ‘/ScadaComm/OpenKPs/KpSms/’.
    Building directory ‘/ScadaComm/OpenKPs/KpSnmp/Properties/’.
    Building directory ‘/ScadaComm/OpenKPs/KpSnmp/’.
    Building directory ‘/ScadaComm/OpenKPs/KpTest/Properties/’.
    Building directory ‘/ScadaComm/OpenKPs/KpTest/’.
    Building directory ‘/ScadaComm/ScadaCommCommon/Channels/UI/’.
    Building directory ‘/ScadaComm/ScadaCommCommon/Channels/’.
    Building directory ‘/ScadaComm/ScadaCommCommon/Devices/’.
    Building directory ‘/ScadaComm/ScadaCommCommon/Properties/’.
    Building directory ‘/ScadaComm/ScadaCommCommon/’.
    Building directory ‘/ScadaComm/ScadaCommCtrl/Properties/’.
    Building directory ‘/ScadaComm/ScadaCommCtrl/’.
    Building directory ‘/ScadaComm/ScadaCommMono/Properties/’.
    Building directory ‘/ScadaComm/ScadaCommMono/’.
    Building directory ‘/ScadaComm/ScadaCommSvc/Properties/’.
    Building directory ‘/ScadaComm/ScadaCommSvc/’.
    Building directory ‘/ScadaData/ScadaData/Client/’.
    Building directory ‘/ScadaData/ScadaData/Data/Configuration/’.
    Building directory ‘/ScadaData/ScadaData/Data/Models/’.
    Building directory ‘/ScadaData/ScadaData/Data/Tables/’.
    Building directory ‘/ScadaData/ScadaData/Properties/’.
    Building directory ‘/ScadaData/ScadaData/UI/’.
    Building directory ‘/ScadaData/ScadaData/’.
    Building directory ‘/ScadaData/ScadaData.Dao/Properties/’.
    Building directory ‘/ScadaData/ScadaData.Dao/’.
    Building directory ‘/ScadaData/ScadaData.Svc/Properties/’.
    Building directory ‘/ScadaData/ScadaData.Svc/’.
    Building directory ‘/ScadaData/ScadaDataTest/Properties/’.
    Building directory ‘/ScadaData/ScadaDataTest/’.
    Building directory ‘/ScadaDoc/ScadaDoc/js/’.
    Building directory ‘/ScadaDoc/ScadaDoc/lib/prism/’.
    Building directory ‘/ScadaDoc/ScadaDoc/Properties/’.
    Building directory ‘/ScadaDoc/ScadaDoc/’.
    Building directory ‘/ScadaServer/FormulaTester/FormulaTester/Properties/’.
    Building directory ‘/ScadaServer/FormulaTester/FormulaTester/’.
    Building directory ‘/ScadaServer/FormulaTester/FormulaTesterExec/Properties/’.
    Building directory ‘/ScadaServer/FormulaTester/FormulaTesterExec/’.
    Building directory ‘/ScadaServer/OpenModules/ModDBExport/DataSources/’.
    Building directory ‘/ScadaServer/OpenModules/ModDBExport/Properties/’.
    Building directory ‘/ScadaServer/OpenModules/ModDBExport/’.
    Building directory ‘/ScadaServer/OpenModules/ModTest/Properties/’.
    Building directory ‘/ScadaServer/OpenModules/ModTest/’.
    Building directory ‘/ScadaServer/ScadaServerCommon/Modules/’.
    Building directory ‘/ScadaServer/ScadaServerCommon/Properties/’.
    Building directory ‘/ScadaServer/ScadaServerCommon/’.
    Building directory ‘/ScadaServer/ScadaServerCtrl/Properties/’.
    Building directory ‘/ScadaServer/ScadaServerCtrl/’.
    Building directory ‘/ScadaServer/ScadaServerMono/Properties/’.
    Building directory ‘/ScadaServer/ScadaServerMono/’.
    Building directory ‘/ScadaServer/ScadaServerSvc/Properties/’.
    Building directory ‘/ScadaServer/ScadaServerSvc/’.
    Building directory ‘/ScadaWeb/OpenPlugins/PlgChart/AppCode/Chart/’.
    Building directory ‘/ScadaWeb/OpenPlugins/PlgChart/AppCode/’.
    Building directory ‘/ScadaWeb/OpenPlugins/PlgChart/js/api/’.
    Building directory ‘/ScadaWeb/OpenPlugins/PlgChart/lib/jquery/’.
    Building directory ‘/ScadaWeb/OpenPlugins/PlgChart/plugins/Chart/js/’.
    Building directory ‘/ScadaWeb/OpenPlugins/PlgChart/plugins/Chart/’.
    C:\Users\vijender panda\Desktop\RapidScada\New folder (2)\Scada\ScadaWeb\OpenPlugins\PlgChart\plugins\Chart\Chart.aspx(1): Build (web): Could not load type ‘Scada.Web.Plugins.Chart.WFrmChart’.
    C:\Users\vijender panda\Desktop\RapidScada\New folder (2)\Scada\ScadaWeb\OpenPlugins\PlgChart\plugins\Chart\MinDataRepOut.aspx(1): Build (web): Could not load type ‘Scada.Web.Plugins.Chart.WFrmMinDataRepOut’.
    C:\Users\vijender panda\Desktop\RapidScada\New folder (2)\Scada\ScadaWeb\OpenPlugins\PlgChart\plugins\Chart\MinDataRep.aspx(1): Build (web): Could not load type ‘Scada.Web.Plugins.Chart.WFrmMinDataRep’.
    C:\Users\vijender panda\Desktop\RapidScada\New folder (2)\Scada\ScadaWeb\OpenPlugins\PlgChart\plugins\Chart\WFrmSelectCnls.aspx(1): Build (web): Could not load type ‘Scada.Web.Plugins.Chart.WFrmSelectCnls’.
    Validation Complete
    ========== Build: 0 succeeded or up-to-date, 1 failed, 0 skipped ==========
    #3925
    You have to switch build configuration from Debug to Release for every solution.
