Viewing 15 posts - 4,681 through 4,695 (of 6,391 total)
  • in reply to: Usage of the popup #4440
    Hi Ben,
    Probably the old scripts are cached by a browser. Clear the browser cache or press Ctrl+F5 in a scheme web page.
    in reply to: Remote commumicator #4431
    If you use remote Communicator, you need the only one Communicator application on a remote PC. Other Rapid SCADA apps should not be installed there.
    In other case, if you have 2 Rapid SCADA servers, you can use Rapid Gate module to transfer data.
    in reply to: Reading bits #4430
    For input channels bound to the same device, signals have to be unique. Anyway, only one channel is bound.
    To use value from a one Communicator tag in many channels use channels of calculated type for other channels except the 1st.
    in reply to: Modbus TCP – One Element value gives 4 Digital Inputs, #4428
    Good!
    For new questions, please create new topics.
    in reply to: Elastic Report Questions #4416
    How to automatically have the number of rows based on the number of parameters available for a specific column for Elastic Report (PDF)?
    Please explain.
    in reply to: Elastic Report Questions #4414
    How to insert page break in Elastic Report (PDF)?
    Where you’d like to insert page break?
    The features you asked require additional development and update of the plugin. The most complex thing is that you need minute data in the report. Currently, the report uses hourly data only due to performance reason.
    Could you provide a report example that you need?
    We can discuss technical requirements here.
    After we clarify all technical details, to get an offer contains the development cost, please write by email.
    in reply to: OPC write value issue-IBH opc server #4413
    Please ask Marc why he doesn’t take into account the QualitySpecified field?
    Mario, I’m interested in solving this issue. Let’s continue the dialog.
    in reply to: OPC write value issue-IBH opc server #4411
    5.5.3 version? I am using 5.5.2
    The OPC driver was not changed.
    in reply to: OPC write value issue-IBH opc server #4410
    As I understand, quality is not specified.
    Item 0:
    vDataValue = VT_BOOL -1
    bQualitySpecified = FALSE
    wQuality = 0x0000 OPC_QUALITY_BAD
    in reply to: Modbus TCP – One Element value gives 4 Digital Inputs, #4409
    Try
    GetBit(Val(100), 0) > 0 ? 0 : 1
    where 100 is the number of the referenced input channel.
    in reply to: Culture 'es-LA' doesn´t takes effect #4408
    Administrator->Settings->Language
    Just type manually. It’s normal. After change here, restart IIS or restart the PC.
    in reply to: Culture 'es-LA' doesn´t takes effect #4407
    You should read this.
    Also check ScadaWeb\log\ScadaWeb.log for additional information about the error.
    in reply to: OPC write value issue-IBH opc server #4392
    We can see the difference:
    In the 1st example:
    IOPCSyncIO::Write
    In the 2nd example:
    IOPCItemIO::WriteVQT
    Can you ask the OPC server developer if they support IOPCItemIO::WriteVQT?
    in reply to: Building a SCADA lab #4391
    I think you should do step by step as shown in the videos.
    in reply to: Chart – samples on the timeline #4372
    Chart Pro plugin display existing data from a “minute archive”. Data are stored in this archive every 1 minute by default. If you set this parameter to 5 seconds by editing ScadaServerSvcConfig.xml, this may affect performance, because such value is not officially supported and tested.
