MikhailModeratorIt can not detect my alarm condition immediately.
You can, but it’s better to tick “Write events” and “Event on change” checkboxes of the input channel. And you will get events in case of alarms.
MikhailModeratorNice ))
Use formulas to divide raw values.
You should download the plugins and copy their files to your RPi.
Thanks for noticing.
Please take the editor from the new version. This bug was fixed there.
This feature is going to be be implemented in a one of future versions, but not in this beta. If your company able to sponsor this feature, it can appear faster. In any case, I hope we will do it.
Unzip and copy *.sdf to C:\SCADA\BaseSDF\
File name should be ScadaBase.sdf
Also you need Communicatior configuration files that located in C:\SCADA\ScadaComm\Config
Let’s do the following:
1. Choose a one register for test purposes.
2. Create a template to poll this one register.
3. Check the settings of the Modbus template (the gear button)
4. Check communication line log.
What is you configuration XML file currently?
Aslo I suggest to ask the autor of the driver on GitHub https://github.com/bersim/OpenKPs/tree/master/KpMQTT
I have a problem in creating a device template,
Please describe your problem and provide screenshots.
MikhailModeratorYou can send command manually or by Automatic Control Module. You need to create output channels in Administrator and create commands in Modbus template.
MikhailModeratorIf i format pc or change sd card on Raspberri Pi, i can still use plugin that i already bought?
If you use the same RPi and keep a computer name unchanged, keys will work.
MikhailModeratorif I buy the automatic control module and other plugins, it will require internet connection to use all plugins
Internet connection is not required.
MikhailModeratorHow can I get the computer the key in Raspberry Pi.
You will find it in scada/ScadaServer/Log/ModAutoControl.log
