DELTA PLC DVP32ES2 device template
Forum Home › Forums › Communicating with Devices › Modbus › DELTA PLC DVP32ES2 device template
  • #5381
    waleed
    I am new in SCADA and I need to connect RapidScada to DELTA PLC DVP32ES2 type.
    I have a problem in creating a device template, as I am new to PLC I have a problem to extract the exact data from manual to create my device template.
    Can I get help please?
    This is the link to the manual I get:
    http://www.deltaww.com/services/DownloadCenter2.aspx?secID=8&pid=2&tid=0&CID=06&itemID=060301&typeID=1&downloadID=DVP-ES2%2fEX2+Series%2c&title=DVP-ES2%2fEX2+Series%2c&dataType=1;3;4;&check=1&hl=en-US
    #5385
    Please describe your problem and provide screenshots.
    #5390
    waleed
    Hi Mikhail,
    This is a screenshot from the Datasheet:
    [IMG]http://i66.tinypic.com/vdedr9.png[/IMG]
    and I have created this device template:
    [IMG]http://i63.tinypic.com/e0khzo.png[/IMG]
    I am not sure if this is correct or not so if you may have a look and let me now if I am doing it right or not.
    #5391
    Let’s do the following:
    1. Choose a one register for test purposes.
    2. Create a template to poll this one register.
    3. Check the settings of the Modbus template (the gear button)
    4. Check communication line log.
