Formula functions send Command to device
Forum Home › Forums › Understanding the Software › Formulas › Formula functions send Command to device
  • #5379
    scadarapid
    My project need to calculate data before send to device via ModbusRTU by write register address. Is is has formula function to send command to device? because I only see function setVal() to set value to database.
    thank you so much.
    #5384
    You can send command manually or by Automatic Control Module. You need to create output channels in Administrator and create commands in Modbus template.
