Restore the database
Forum Home › Forums › Understanding the Software › Restore the database
  • #5392
    tom040264
    Hi guys,
    I guess that the question is too easy and that this is the reason I can not find any answer.
    After a big crash of my computer I had to reinstall the whole SCADA. I have the last Backup data with the name “ScadaBase_2019-05-05_07-51-02” (zip) respectively “ScadaBase” (SQL server compact). Is there any way to restore the Database out from these files?
    Thank you in advance
    T.
    #5393
    Unzip and copy *.sdf to C:\SCADA\BaseSDF\
    File name should be ScadaBase.sdf
    Also you need Communicatior configuration files that located in C:\SCADA\ScadaComm\Config
