Can we monitor the values in server room table with sampling rate less than 1 minute?
It can not detect my alarm condition immediately. It detects only in every cross to new minute.
I have found in the forum this answer from Mikhail:
”As a workaround you can manually set the value in C:\SCADA\ScadaServer\Config\ScadaServerSvcConfig.xml
It defines how often snapshots are stored in minute data file. SCADA-Server shell may display custom values incorrectly despite of that it works.
If you write more details about your task I could give more efficient advice.”
This topic was modified 7 years, 5 months ago by
slmhlm.
