MikhailModeratorYes, I understand. This button is removed. Instead of this, you can use a filter of the Input channels table to filter the records by an object.
Why grouping by devices is not enough for you? What is the specifics of your system?
September 30, 2019 at 1:16 pm in reply to: Change event contains columns, increase whether to eliminate and eliminate time #5982
The GenEvent method is used to generate events. You should find references to the method for researching detailed logic. If you ask particular questions, I’ll try to clarify them.
MikhailModeratorThe driver user interface is implemented.
Use filter of a table.
Can i extract data from them? Or must use modbus port?.
Please read the manual. Likely, you can use Modbus TCP.
First, try to use built-in Ethernet port of the controller if it is presented. I’m not DSE guru, but talk from common point of view.
MikhailModeratorThank you for checking. I added BouncyCastle.Crypto.dll to the ZIP file.
I also tested the driver on Linux. It works but requires an extra step in configuring. If needed, I will describe here.
MikhailModeratorI’ve got a Modbus template for some model of DSE controller. I can share it in case you will share the final template for DSE 7320.
DSE 7320 supports Modbus communication protocol, so it can be connected to Rapid SCADA.
You should do the following:
1. Read this article and watch this video.
2. Create your own simple project to read data from Modbus simulator.
3. Find the Modbus register map for DSE 7320 in the manufacturers documentation.
4. Create your Modbus template DSE 7320 for that specifies the registers to read.
MikhailModeratorIn the Interface table you have to specify @ElasticRep as shown here
http://doc.rapidscada.net/content/latest/en/modules/plg-elastic-report-files/report_itf_tbl_en.pngReports are listed at http://localhost/Scada/Reports.aspx
Please make the following screenshots:
1. Of the page http://localhost/Scada/plugins/Config/Plugins.aspx
2. The Interface table in the Administrator app.
This feature requires additional development. We can implement it by a contract.
MikhailModeratorYes, this is a significant bug.
We plan to refactor the driver inside the https://github.com/RapidScada/scada-community repository.
MikhailModeratorCould you explain:
1. What is Thingsboard?
2. Why this device can not be polled as usual?
MikhailModeratorDo you mean that the issue is fixed?
The latest version of KpMqtt.dll is available at https://github.com/RapidScada/scada-community/releases
